cj5 lifted now spring hits tie rod - JeepForum.com
post #1 of 3 Old 01-27-2010, 05:39 AM Thread Starter
staplesmotorspo
I put a 4" lift on my cj5, Now my tie rod does not clear the spring. Has anyone run into this problem. It looks like I could put the tie rod on the top side of the spindle, but that would require different ends and reaming the holes. I was hoping there is an easy way. Any help would be greatly appreiciated.
staplesmotorspo is offline
post #2 of 3 Old 01-27-2010, 09:08 AM
jeepskate
Do you mean the drag link? Did you install a drop pitman arm? You can do a rod flip with inserts & a reamer (a few of us have the reamer and will lend it out).
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 3 Old 01-27-2010, 01:59 PM Thread Starter
staplesmotorspo
its the tie rod that goes from spindle to spindle when it crosses over the springs there is no clearence. Is flipping it to the top side the only cure for it.
Clutch Problem!!! Throwout Lever Hits Bellhousing!! Hondaluvr1985 Jeep CJ Forum 10 01-10-2013 10:37 AM
Window crank hits roll cage--ideas? cyclic17 Jeep CJ Forum 12 02-18-2009 07:28 PM
stick shift hits dash tony dz Jeep CJ Forum 7 06-20-2007 07:08 PM
cj 5 lift drag link hits spring webjeepin Jeep CJ Forum 2 03-17-2006 07:22 PM
transfer case hits skid plate dpoliver Jeep CJ Forum 4 06-12-2002 04:24 PM
