CJ5 lift? - Page 2 - JeepForum.com
post #16 of 26 Old 09-27-2013, 07:02 AM
fiddy5cj5
1955 CJ5
Is it the sane for the older Willys I have a cj3a and I've got the springs, spring plates and all the hangers and shackles what else might I need on the older cjs
Sorry not trying to hijack the thread but I've tried asking in my own post with no luck and all my research shows stuff for newer cj5s
fiddy5cj5 is offline
post #17 of 26 Old 09-27-2013, 07:08 AM
superj
aren't the older cjs set up on a different style spring? i would imagine you could swap to anything you want as long as you have a welder, though
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #18 of 26 Old 09-27-2013, 08:32 AM
fiddy5cj5
1955 CJ5
Ya they are but it should be a matter of just changing the hangers and plates right or am I forgetting something
post #19 of 26 Old 09-27-2013, 09:46 AM
Chewtoy
1976 CJ5
Originally Posted by Bigkahuna View Post
Thank you I will make note of that. Any recomendations for a YJ spring conversion for early CJ?
Earliest Jeep I have any experience with is '76. I don't think it would be a whole lot different, but I am just guessing. I understand at some point the earlier CJs had even narrower springs than mine, at which point I would think you would need a wider spring pad.
This is a great forum for early CJs. http://www.earlycj5.net
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #20 of 26 Old 09-27-2013, 10:44 AM
big_o_tom
1978 CJ7
I had a 2.5" rancho with 33's, now I have a 4" skyjacker and 35's. I had to do a little wheel well trimming and I really like it. I think it rides better than the rancho. Got it and bushings and u bolts for $350 brand new off a guy that had decided not to lift his jeep!
big_o_tom is offline
post #21 of 26 Old 09-27-2013, 10:48 AM
fiddy5cj5
1955 CJ5
What year jeep
post #22 of 26 Old 09-27-2013, 11:51 AM
superj
looks like a 78
superj is offline
post #23 of 26 Old 09-27-2013, 10:58 PM
big_o_tom
1978 CJ7
My jeeps a "78. I sold my 2.5" lift to a friend at work who has a cj5. I rode in his jeep today and I dont know if its the difference in springs or the added length of my cj7 but my jeep rides a lot better.
post #24 of 26 Old 10-02-2013, 02:56 AM
willp07
1964 CJ5
Any CJ that is pre 76 (dont quote me on the year) will have 1.5" wide springs front and rear. 76 and on have 1.5" up front and 2.5" in back. YJ springs are 2.5" and have more thin leafs in the pack, with the same eye to eye length, the reason why they are a good swap. This results in a much better ride quality and flex off road. If swapping, youll have to get new spring and shackle hangers either front or front and rear depending on year and either bolt or weld them on after cutting the old hangers off. You will also want to consider but not necessarily required, welding on new spring perches on your axle or axles. This really is the way to go if your planning on lifting your CJ or just want a better ride.
Another option that is popular is going with wagoneer springs which are the same eye to eye length and width as the YJ springs but have an offset pin, giving you a slight 1.5-2" axle stretch if thats what your looking for as well, without moving hangers around. (again dont quote me on the exact number its off the top of my head and late right now, haha)
I saw some people spoke of SOA, which is what Ive done on mine. You need to be even more careful about going this route, because doing it correctly is even more expensive than an SUA lift, and a lot more work.
Finally, for most on here doing mixed road trail use, and mild to moderate trails, a YJ spring swap + lift is in my opinion the best route.
Buying quality springs is all about ride quality and longevity (lifespan) of the springs. RE, Alcan, Deaver are a few that come to mind.
willp07 is offline
post #25 of 26 Old 10-02-2013, 12:51 PM
Chewtoy
1976 CJ5
Just a minor correction here. 76 and later CJs have 2" spring up front and 2.5 in back. Not trying to be a jerk, just trying to keep the information accurate.
Chewtoy is offline
post #26 of 26 Old 10-02-2013, 02:48 PM
willp07
1964 CJ5
No problem. I wrote that at work around 1am and ran out of coffee so the numbers start jumbling up on me, Haha.
willp07 is offline
