Quantcast CJ5 ignition - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ5 ignition
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 05-22-2005, 08:54 AM   #1
ministock#8
CJ5 ignition
hello all, i'm doing a little research for my brother who isn't to computer literate. he has a jeep cj 5 hes restoring. fibreglass body 258 6 cyl. the question is does anyone have a wiring diagram for the ignition on these. also i'm not sure what to call it but on my stock car its called an ignition box (ford 2.3 dura spark) i read somewhere that these setups were similar. what does he need.
thanks
ministock#8 is offline   Reply With Quote
Old 05-22-2005, 01:08 PM   #2
cropduster
thanks
Try this link for all of your jeepin mechanical and other needs: http://www.geocities.com/cantwait_forviolence/cj_index.html
Its full of goodies.
barryb
1984 CJ8 w/258 and 4 speed. TFI w/Delco module, propane power, 3" lift
2001 Toyota Tacoma 4WD 6 cylinder
cropduster is offline   Reply With Quote
Old 05-27-2005, 07:03 PM   #3
ministock#8
thats it??
is that all? one responce. come on now
Old 05-27-2005, 08:53 PM   #4
mxg342
Haynes and chiltons manuals have the diagrams needed. I suggest you pick one up for a project this size.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline   Reply With Quote
Old 05-28-2005, 12:00 AM   #5
Geer_hed
Well if you digged a bit on that link crop posted for you, you would've found these. It would also help a bit to know what year cj5 this is, that would definitely help determine ignition setup. Since you're seeing a duraspark ignition module, then I guess we can assume it's a 74 or later.
There were a few different duraspark generations, and I'm still trying to hammer down which version was implemented where in jeep production, but odds are the setup is duraspark I...
[center][color=black][b]85 CJ7 / 258 / T176 / Dana 30/ AMC 20[/b][/color]
[url=http://www.geocities.com/cantwait_forviolence/]My Online Dumping Ground[/url][/center]
Geer_hed is offline   Reply With Quote
Glock Forum
