CJ5 Half Top? - JeepForum.com
post #1 of 5 Old 03-19-2013, 12:36 PM Thread Starter
requiembell
1983 CJ5
CJ5 Half Top?
Will a half top for a CJ8 fit a 1983 CJ5 without major modification?
requiembell is offline
post #2 of 5 Old 03-19-2013, 02:29 PM
sgtbookie
Well a CJ8 has a significantly longer wheelbase than a CJ 5. Might have better luck modifying one from a CJ7.
2005 LJ Rubicon Sahara #380
sgtbookie is offline
post #3 of 5 Old 03-19-2013, 03:13 PM
Al_77cj5
1977 CJ5
roll bar is going to be in the way. If you remove it you could put the top on. you would have to make custom doors though as your doors will not line up.
97 tj wrangler, 77 cj5, 78 cj7, 76 j10, 53 cj3b, 81 amc eagle wagon
Al_77cj5 is offline
post #4 of 5 Old 03-21-2013, 09:37 AM
Pathkiller
1974 CJ5
Short answer is no, it won't work. The top rails of the CJ5 tub are a completely different shape from the CJ7/8 and about 2" shorter. That's aside from the issue of not having doors that would work. The lower bulkhead also wouldn't work in a CJ5 tub, so the half cab wouldn't have anything to seal against.
But the real question is why? There were steel half cabs available for CJ5's that can still be found. They're certainly no rarer than the only 26,000 Scrambler half cabs that were made, and much cheaper.
Pathkiller is offline
post #5 of 5 Old 03-21-2013, 10:28 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would buy it, sell it to someone who desperately needs a CJ 8 top and use the money to pick up a CJ 5 top....
John Strenk is offline
