CJ5 Fuel Tank Problem - JeepForum.com
post #1 of 14 Old 06-23-2013, 05:50 PM Thread Starter
tindlejd
1972 CJ5
So I have a 1972 CJ-5 and need to find a new rubber piece to go around the fuel hose. This piece protects the fuel hose from the body. All the rebuild manuals call it a "grommet". I can't find this part in any magazine or online.
tindlejd is offline
post #2 of 14 Old 06-23-2013, 06:09 PM
petey156
1977 CJ5
A piece of old radiator hose may work in a pinch
petey156 is offline
post #3 of 14 Old 06-23-2013, 08:12 PM Thread Starter
tindlejd
1972 CJ5
Thanks didn't think about that.
tindlejd is offline
post #4 of 14 Old 06-23-2013, 08:58 PM
BuckeyeNative
BuckeyeNative's Avatar
1974 CJ5
#tindlejd...apologize in advance but I am going to hijack your thread with another fuel tank problem.
The PO did a tank relocated to the back with a CJ7 system. The fuel filler hose has a hole for the vent tube. Does anyone make the metal piece which the connects the vent tube from the filler hose? I have been on the major Jeep aftermarket stores but can't locate this part. Any assistance would be greatly appreciated.
BuckeyeNative is offline
post #5 of 14 Old 06-23-2013, 10:34 PM
petey156
1977 CJ5
On late model cj's the the vent hose connects to the filler neck where they hook to the tub...
petey156 is offline
post #6 of 14 Old 06-24-2013, 05:22 AM
OleBlue73
1973 CJ5
http://www.jeep4x4center.com/filler-...s-cjfhn-1.html
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #7 of 14 Old 06-24-2013, 05:34 AM
BuckeyeNative
1974 CJ5
Thanks....I wasn't sure what the part was called.
post #8 of 14 Old 06-24-2013, 10:25 AM
wblackm
tindlejd,
Was bored at work and ran across you while I was reading through. Anyways I found a couple of links here that I believe have what you are looking for...
http://www.the-jeep-guy.com/fuel_&_intake_systems.htm
http://justgastanks.com/product_info...roducts_id=684
Talk to you later.
wblackm is offline
post #9 of 14 Old 06-24-2013, 10:38 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Do you need the part that screws directly into the hose?
The HOSE BUNG?
[From wblackm links above...
John Strenk is offline
post #10 of 14 Old 06-24-2013, 12:10 PM
OleBlue73
1973 CJ5
The hose bung is what I linked above from Morris. I actually bought mine from the Jeep Guy. The repro part is identical to the original and USA made.
2009 JKU, Rubicon
post #11 of 14 Old 06-24-2013, 12:27 PM
John Strenk
1976 CJ5
Ah yes, i see it now. Just viewed from a different angle...
post #12 of 14 Old 06-24-2013, 06:30 PM
BuckeyeNative
1974 CJ5
Yes...that is it. I can assure you I wouldn't have Google searched for a "hose bung" for fear of what the results would have been.
I am new to the Jeep world and appreciate all the help and links.
post #13 of 14 Old 06-25-2013, 07:31 AM
John Strenk
1976 CJ5
to this day I still call Alligator clamps, roach clips.
post #14 of 14 Old 06-27-2013, 01:45 AM
WSS
WSS's Avatar
1972 CJ5
Interestingly enough, I have never clamped an alligator with one. You learn something new all the time here on JF. LOL
I just put in a new tank/sender/hold down ring from Morris and used the short fill neck version in hopes it would be less likely to crack around the base, it also fills WAY better at the pump.
WSS is offline
