CJ5 front axle seal leaking - JeepForum.com
post #1 of 4 Old 12-28-2008, 03:08 PM Thread Starter
clerihew82
1977 CJ5
I have a 77 cj5 and my front axle seal is leaking. Ive taken the axle shaft out and i see a seal in there about a foot inside. How do you get in there to change it out?? Do you have to take the axle housing cover off?
clerihew82 is offline
post #2 of 4 Old 12-28-2008, 03:45 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yep.. the seal gets replaced from inside the differential center section. You have to remove the axles, remove the ring gear carrier, get the old seal out and press a new one in from the inside out. Might as well do both sides while you're in there.
BESRK is offline
post #3 of 4 Old 12-29-2008, 03:04 PM Thread Starter
clerihew82
1977 CJ5
what is involved in removing the gear carrier? Ive seen some pics that show you get both axle shafts out and remove the diff cover. And take off two holders?? on each side of the gears. I guess. Mabye somebody can clear that up a little easier. I have a chiltons manual but it doesnt say much about that at all. thanks
post #4 of 4 Old 12-29-2008, 06:34 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If it's never been apart before, it can be kind of tough to get the carrier out. You should use a "case spreader" to open the differential housing up a tiny bit.. releasing the clamping force on the carrier bearings. However, lots of folks take a couple long screw drivers (or prybars) and pry on the ring gear bolts at the top/bottom of the case... sort of levering the carrier out of the housing. If you do that, it helps to have an extra set of hands. Even a Dana 30 carrier is pretty heavy while laying on your side prying with screwdrivers. Be careful not to drop it on the ground.. or on your fingers. Also, keep track of everything you take out.. those bearing caps must go back on in the original position.
If you're not sure of your mechanical abilities, you may want to solicit the help of someone who's done this before to avoid making costly mistakes.. maybe locate a local Jeep club and ask around for some help?
BESRK is offline
Speedy Seal - Leaking Rear Main Seal h2obuff Jeep CJ Forum 18 11-22-2009 07:16 PM
Changing front axle seal 79 CJ jatepper Jeep CJ Forum 5 04-25-2007 07:02 AM
T5 Trans - Leaking Front Seal Hibbitz Jeep CJ Forum 5 07-07-2006 07:39 PM
T5 Leaking front seal from overfill? BUGS Jeep CJ Forum 12 03-22-2006 08:17 PM
74 cj5 rear axle seal leaking GRN74cj5 Jeep CJ Forum 18 08-15-2005 05:27 PM
