CJ5 Floor Pan Replacement - JeepForum.com
post #1 of 6 Old 03-03-2009, 09:50 AM Thread Starter
bakerpulliam
2015 JK Wrangler
I need to fix some rusted front floor pans. Where is a good place to get info on how to cut out and replace my pans?
bakerpulliam is offline
post #2 of 6 Old 03-03-2009, 10:45 AM
COBRA5LADDICT
i did a full floor when i did mine.. it saved quite a bit of time and came out cleaner i feel. below is a link from my build, it covers the floor too, if you have any other questions just ask.
http://www.jeepsunlimited.com/forums...d.php?t=333737
COBRA5LADDICT is offline
post #3 of 6 Old 03-03-2009, 10:47 AM
JoonHoss
2011 JK Wrangler
do you want to make your own, or just buy prefabbed?
best way to make your own is buy scribing a heavy paper template, which will allow you to make a pattern, but lay flat for cutting
Molsenice is one member on here who has done a ton of patch panels (as have many others), I recommend looking through his build thread....
http://www.jeepforum.com/forum/f8/cj6-build-here-i-go-again-620861/
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #4 of 6 Old 03-03-2009, 03:12 PM
Bubba Ray
Classic Ind. makes the best repair panels hands down!
Bubba Ray is offline
post #5 of 6 Old 03-09-2009, 06:26 AM Thread Starter
bakerpulliam
2015 JK Wrangler
Rusted floor pan replacement
Thanks yall....... I looked at the links but had trouble with the pictures and stuff. I just need some advise for putting the replacement pans back in after I cut the old ones out. I plan to order the replacement pans from Classic. Some folks say to butt joint the panels and weld them while others say to overlap the panels. Overlaping will be stronger but is it hard to get the welds smooth enough to conceal the weld joints? Thanks for all the help. Yall are awesome!!!!
post #6 of 6 Old 03-10-2009, 07:09 PM
Bubba Ray
I did a small overlap but you can see the joints. I just don't care. The primer and paint hide it some.
help floor or tub Austy12345 Jeep CJ Forum 3 06-25-2009 06:30 PM
84 cj7 has no floor Austy12345 Jeep CJ Forum 11 06-24-2009 06:11 AM
floor replacement tips? and info needed kjeepcherokee Jeep CJ Forum 2 05-28-2007 06:37 AM
Floor replacement pan pasinbuy Jeep CJ Forum 9 02-11-2007 08:45 PM
Replacement floor panels collinpyle Jeep CJ Forum 12 07-08-2006 12:42 AM
