CJ5 Factory Steering Linkage is too short? - JeepForum.com
post #1 of 11 Old 01-10-2010, 01:13 PM Thread Starter
Jeaux
Help! I bought this CJ5 with a bad steering box. i have replaced the box only to find the linkage was bad as well. I ordered a Factory Steering Linkage and it looks like it is too short? By 2". On the lower coupler I would have to pull this out about 2" in order to be able to insert the bolt in the proper place. Is this normal? I feel that is not. I do not see a body lift kit or any other reason why the steering wheel would be further away from the factory located steering box.
Thanks Jeaux.
Jeaux is offline
post #2 of 11 Old 01-10-2010, 02:01 PM Thread Starter
Jeaux
Can anybody help?
Im wanting to do this now?
Jeaux is offline
post #3 of 11 Old 01-10-2010, 02:09 PM
scooter
1982 CJ7
You talkin about the drag link from the box to the knuckle?
scooter is offline
post #4 of 11 Old 01-10-2010, 02:17 PM Thread Starter
Jeaux
Drank Link?
The shaft under the hood that connects the steering column to the steering box.
I have to pull on the lower coupler of that linkage to stretch it enough to put the bolt in connecting the linkage to the steering box.
Jeaux is offline
post #5 of 11 Old 01-10-2010, 02:22 PM
scooter
1982 CJ7
That would be the steering shaft. Id take some measurements off my 82 7 but im sure its different,other than than im no help....sorry.
scooter is offline
post #6 of 11 Old 01-11-2010, 05:39 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Do you have a body lift? if so, that is your problem (might help us by filling out your Jeep information) . If so, you may have to "extend" the shaft by driving the lower section out of the slip joint.
jeepdaddy2000 is offline
post #7 of 11 Old 01-11-2010, 08:48 AM Thread Starter
Jeaux
I'm not sure. I don't see any spacers under the body. No large shocks, just the shackles you can see in this picture.
And when you say extend the shaft by driving the lower section out of the slip joint.
You don't mean completely out do you? 2" at best will be the most I can pull on the lower coupler "Slip Joint" but I am afraid that this will make it weak and will break on the first trail.
Jeaux is offline
post #8 of 11 Old 01-11-2010, 10:04 AM
John Strenk
John Strenk's Avatar
1976 CJ5
2" seems like a lot. Did you place the steering shafts side by side and check the measurements?
One time I accidently pushed my steering column up and it slipped off the bearings. Until I went inside and looked at the steering wheel I thought I had the wrong length shaft also.
John Strenk is offline
post #9 of 11 Old 01-11-2010, 11:24 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Steering shafts have slip joints in the middle. Make sure the shaft has not been compressed.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #10 of 11 Old 01-11-2010, 11:33 AM Thread Starter
Jeaux
The shaft I ordered is the same as the one i took off in fact that is how I broke the old one one.
Any way I was just told to punch out the two plastic pins in the linkage. This will give me the extra length I need.
Thanks for all the reply's.
jeaux
Jeaux is offline
post #11 of 11 Old 01-11-2010, 12:18 PM
Mike Romain
jeaux
Not in the linkage, in the middle of the shaft, where the compression joint is are the two plastic pins.
Mike
Mike Romain is offline
Dana 30 Steering Linkage ??? cj7roaddog Jeep CJ Forum 7 02-12-2009 05:26 PM
Steering Column too short Hunts4ducks Jeep CJ Forum 10 06-04-2008 01:33 AM
steering shaft linkage cityofcompton3 Jeep CJ Forum 1 07-19-2006 06:16 PM
steering linkage aksourdough Jeep CJ Forum 2 09-13-2005 09:32 PM
What is this part in the steering linkage? '83Laredo Jeep CJ Forum 2 05-08-2005 01:58 PM
