Cj5 exhaust routing pics? - JeepForum.com
post #1 of 4 Old 10-21-2013, 01:03 AM Thread Starter
ridge28
1964 CJ5
It's got some headers on my 64 and have had them running outside the frame rails into mufflers to turnouts, it's still way to loud for me, anyone have there's setup to run all the way back on the outside of the frame rails? Any pictures? Is there enlightened clearance to run it past the springs and tires, especially when I'm flexing?
ridge28 is offline
post #2 of 4 Old 10-21-2013, 12:56 PM
WSS
WSS's Avatar
1972 CJ5
Here is mine, you can see most of the path. Both sides are pretty much the same, no problems with it yet.
WSS is offline
post #3 of 4 Old 10-21-2013, 02:22 PM Thread Starter
ridge28
1964 CJ5
How close are your tires getting when you flex out?
ridge28 is offline
post #4 of 4 Old 10-21-2013, 06:32 PM
WSS
WSS's Avatar
1972 CJ5
It will touch touch the tub wheel wells first, they are tucked pretty good. I do have a 1" body lift, so it has a little more room than stock. That said, when the wheel is tucked has at least 2" between wheel and exhaust tube. I notice on the pass side that the front part of the tube (the 45 degree part) has a little rub mark, that means the springs are wrapping a bit
WSS
WSS is offline
