CJ5 engine cough - JeepForum.com
post #1 of 3 Old 02-04-2012, 04:19 PM Thread Starter
SugarBear
1969 CJ5
CJ5 engine cough
In my '69 CJ5, I have a buick dauntless 225, and I might have an issue.. When I'm driving at about 50, in third gear, my jeep will be cruising fine, but about every ten minutes, the engine will sort of cough.. Like a brmmmmmm-stop-brrrrmmmm. I know that sounds goofy, but I'm sure someone will know what I'm talking about. I need to know what could be the issue. Jeep idles fine, and runs strong, it just cuts out for a split second sometimes, and I can feel it.. Any help is appreciated.
Caleb
1969 CJ5
2.5" Rancho Kit/Shocks/Steering Stabilizer, 2" Shackles, Koenig PTO Winch, 31x10.5x15 Cooper STT's
SugarBear is offline
post #2 of 3 Old 02-04-2012, 04:38 PM
Trapshooter
Sudden loss of engine power typically is caused by ignition failure. Fuel issues tend to exhibit a slow loss of power as opposed to sudden.
I would double check your ignition system for any loose connections, especially around the coil.
Does the power loss ever occur after hitting a bump? Do you ever get a backfire?
Good Luck.......
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 3 Old 02-04-2012, 06:21 PM Thread Starter
SugarBear
1969 CJ5
I only get backfire when I'm using engine braking, but other than that, no. It seems like it might be occuring after bumps like you said.. I'm going to check right now, around the distributor and the spark plug wires.. Hmm..
1969 CJ5
