CJ5 and CJ7 comparison - JeepForum.com
post #1 of 7 Old 04-15-2012, 06:29 PM Thread Starter
thartleystj
Hello all! I am new to CJ world and I am trying to decide between a later model CJ5 and a CJ7. So with this post I'm asking all you CJ owners what are the pros and cons of each and which do you prefer? I like the shortness and overall look of the body on the CJ5 but I like that there are more aftermarket parts available for the CJ7...so again I ask what's the pros and cons of each and which do you prefer? Thanks in advance
Sincerely,
CJ Noob
1999 Jeep Wrangler TJ
4" Lift Kit, 20" XD Rockstars w/32" Nitto Terra Grapplers
thartleystj is offline
post #2 of 7 Old 04-15-2012, 06:42 PM
clydegoat
mostly be what you like, pretty well the same mech. in both jeeps, just the 5 is little shorter, like me I like the looks of the 7 better, I like the bigger door opening in the 7. seems like you can get the 5's a little cheaper, think the 7's are more popular(supply and demand I guess). engines, trannys, rear ends all the same for the comparable year. 7's with the longer wheel base give you a little more room to work with if you want to add things(or have one with) and auto. tranny. hoods, grills, windshield frames will swap. just differant body.
clydegoat is offline
post #3 of 7 Old 04-15-2012, 06:46 PM
BagusJeep
1981 CJ7
If you are going to use it as a DD you may find the longer wheelbase will make it less twitchy and the slight increase in space is welcome. The CJ7 also can be found with a hardtop and steel doors which makes it more practical as a DD. There is slightly more legroom for the passengers.
The CJ5 is a shorter wheelbase so has an advantage off road and if all you intend to do is wheel it in the mud and across rocks the CJ5 may be a slightly better alternative.
No matter what you go for get one in as good condition as you can afford.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 7 Old 04-15-2012, 06:48 PM
Altimeter
1997 XJ Cherokee
If you are taller than about 5'10", you may want to opt for a 7. I have a 5, I'm 5'9" tall, and I feel like I need to be back a few inches. It also took me a while to not hit the door hump every time I got out of it. Also, if you need to haul around more than 2 people routinely, you'll need a 7. Having said that, I love my 5.
1997 Sport XJ - DD
Gone:
1990 MJ, 1998 XJ Sport, 1977 CJ5, 1993 ZJ, 2006 TJ
Altimeter is offline
post #5 of 7 Old 04-15-2012, 06:48 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
FWIW, the CJ-5 isn't very fat guy friendly.
Being as I'm a "full-size" guy, and I really prefer the looks of the CJ-5, I'm just not physically comfortable in them.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 7 Old 04-15-2012, 06:52 PM Thread Starter
thartleystj
It's mainly going to be an offload vehicle. Mainly because I have a wife and 3 kids so we won't fit in one no matter what. I'm wanting to find one as close to stock as I can get because I was to do everything my self. I used to have a to and I bought it with some things done to it and I regretted it because the po cut corners on some of the necessary upgrades like the lift kit and did chep bed liner on it but thought it was fine to spend $3700 on 20" Rosckstars and 35" Mud Grapplerswhich I immediately sold. So this time I kinda wanna do it all my self or at least most of it so corners don't get cut
post #7 of 7 Old 04-16-2012, 08:17 AM
Rattyflatty
1948 CJ2A
Hold out for a Cj6 or a Scrambler and build in third row seating.
Tonight we drink for tomorrow we shoot bang bang
Rattyflatty is offline
Comparison between 4.2L and 4.3L Skerr Jeep CJ Forum 3 09-04-2011 01:06 PM
CJ-5 Seat Comparison neilmuehlhausen Jeep CJ Forum 7 02-09-2011 12:29 PM
Battery cable lug comparison h2ojeep Jeep CJ Forum 14 11-11-2009 08:15 AM
HEI Comparison? neilmuehlhausen Jeep CJ Forum 3 05-21-2008 04:56 PM
CJ-5 top rear Size comparison?? nitros-CJ5 Jeep CJ Forum 2 03-13-2003 06:19 PM
