CJ5 With 33's on 4" Suspension and 1" Body - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ5 With 33's on 4" Suspension and 1" Body
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-29-2007, 07:30 PM   #1
Jeff5886
1983 CJ5
Well I orderd my lift wheels and tires today for my 83 CJ5. 4" RC Suspension lift, 33x12.50R15 BFG All Terrains, and 15x10 MT Classic II's. Upon leaving the off rod shop here, I noticed..................I have a 1inch body lift on my Jeep from the PO. Anyone got this setup? Please provide pics!
Jeff5886 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2007, 08:24 PM   #2
supraman1990
1980 CJ5
Any reason why you only went with the 33? I'm going to be running a 4 inch suspension and one inch body and know I can fit a 35 without any real issue.
supraman1990 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2007, 10:11 PM   #3
81 cj 5
if you put 35 on you will have some rubbing mine has 4inch lift and a one inch body and when im off road and i get to twisting mine up i rubb with 33 s
81 cj 5 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2007, 10:48 PM   #4
bjf498
1983 CJ7
here's a cj7 with a 4" lift with revolvers, and a 1" body lift and 33's
the tires look a tad small with that much lift but i wouldn't go an bigger with a dana 30 up front
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2007, 04:04 AM   #5
Jeff5886
1983 CJ5
thanks, any mroe pics?
Unread 06-30-2007, 11:59 AM   #6
jayhawkclint
1970 CJ5
CJ5, 4" ProComp lift, stock body mounts, 34" Swamper LTB:
My '70 CJ5 Build Thread:
http://www.jeepforum.com/forum/f8/my...thread-359375/
jayhawkclint is offline   Reply With Quote Quick reply to this message
Unread 06-30-2007, 12:22 PM   #7
80cj
80cj's Avatar
1980 CJ5
Leave it like that. It should look great.
80cj is offline   Reply With Quote Quick reply to this message
Unread 06-30-2007, 10:32 PM   #8
kbtriumph
Here's my CJ6 with a 2.5" lift, about a 1" body drop and 33X10.50 Swampers.
With this setup I had to adjust the steering stops a little to keep the front tires out of the springs but that was the only rubbing I had.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline   Reply With Quote Quick reply to this message
Unread 07-01-2007, 10:17 PM   #9
Jeff5886
1983 CJ5
anyone got any more pics?
Unread 07-02-2007, 06:58 AM   #10
rivers edge
Mine has a 4.5" RE with a 2.5" shackle reversal, and 33x12.5 boggers. It rubs a little bit at full flex and the tires turned! I could easily clear 36" tires, but if I wheel my jeep I will be shuving tires up in the fenders! Here:
www.riversedge4x4.com
'78 CJ- 5 (O'l Green), '99 TJ on rocks (li'l man), '07 JK (rattle can)
rivers edge is offline   Reply With Quote Quick reply to this message
Unread 07-02-2007, 09:44 AM   #11
supraman1990
1980 CJ5
mmmmmmm, CJ6.
Unread 07-02-2007, 10:48 AM   #12
jayhawkclint
1970 CJ5
My '70 is also 4" with 33" tires, but different era CJ:
