#1 | |
cj5 2 questions
ok i have a cj5 i just got and getting another one in a week or so. question is can i swap a body from a another jeep ? i know you can on a cj7. puttin a yj body on a cj7 frame already done that. must say was pretty easy. but as far as a cj5????????? and another thing how hard is it to pto on a cj5 i heard they had them at one time. would like to put one on my cj5 so i can get to some harder feilds i have to bush hog. any help would be great i have a 78 cj6 and a 70 something not sure till i get it. thanx
its like a puzzle so many little peices maybe i shouldnt have been drinking when i was restoring? |
#2 |
Depends on how original loooking you want your Jeep. If you're just worried about it "fitting," then '55-'75 tubs are interchangeable with one another, and '76-'83 are also interchangeable. The frames changed with the '76 AMC redesign, so body mount locations are different from that model year and up. There are many different cosmetic differences between eras, but what I listed should "fit." Hope that helps.
My '70 CJ5 Build Thread: http://www.jeepforum.com/forum/f22/my-jeep-build-thread-359375/ |
#3 |
The PTO depends on the tranny, some have a PTO output some dont. I dont knwo which all have them and which dont but you shoudl be abel to find out if you know what tranny u have.
#4 |
Sorry, missed the PTO question. Also depends on year. It would be easiest to install a PTO if you have a pre-'72 JEEP (CJ2/3/5/6) with a D18 t-case. There is a PTO port directly behind the tranny output shaft that will allow you to run a PTO straight to the back.
#5 |
i have a '75 cj5 for parts that has a PTO right off the tranny(T18). ran a pump and had live lines to the rear of the jeep
'45 MB '73 CJ5, 360, 33's, 3" lift '77 CJ5, 304, 31's, plow rig '80 FJ40 '93 stock YJ |
#6 |
pm sent yooper 055
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
