cj3a swaps - JeepForum.com
post #1 of 2 Old 05-19-2005, 07:01 PM Thread Starter
blackyj
blackyj's Avatar
cj3a swaps
hi all. just picked up a nonrunning cj3a. and i have a amc 360 i would like to put in it. will the driveline hold up? if not what is a good swap? i have 3 grand wagoneers with 360s and auto trans. dana 44s. what do you think. and do you have photos of a 3a all dune up with big tires and fullsize axles?
BLACK 95 YJ 2.5L 31X10.5 TRXUS M.T, HOME MADE FRONT BUMPER,HOME MADE REAR BUMPER WITH SWING AWAY TIRE CARREIR,OLYMPIC NERF BARS,HILIFT,KC LIGHTS,BEST TOP REPLACE-A-TOP WITH TINTED WINDOWS,lots of diamond plate, DYNOMAX MUFFLER, ELECTRIC COOLING FAN, JUNK YARD POWER STEERING,and a 2" body lift.2"add a leaf. 2002 grand cherokee, 77 cj5 32x11.5x15 m.t. 4"trailmaster, 2"shackles fiberglass everything,hardtop,bestop seats.
blackyj is offline
post #2 of 2 Old 05-19-2005, 07:43 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The 3 with a 360 is going to be a bit overpowered. The front axle is weak at best, and the trans is marginal. If you go and mesure the length of the drive train complete and check the room under the CJ, you will find that there won't be much of a rear driveshaft. For fit and power, a V6 is the ticket. A Buick will go in nicely, and the adapters are readly available. The length of the engine will give you a little more leeway as far as picking a trans,as well as keeping the grill cutting to a minium. The FSJ axles are going to be a bit wide, and require some modification. I would go out and with a tape measure and get an idea of what some of the dimentions are. This will answer a lot of questions.
jeepdaddy2000 is offline
Cj3a Milspec Jeep CJ Forum 3 03-08-2011 06:44 PM
cj5 cj3a floor pan tell me what it is baystrucksalvag Jeep CJ Forum 5 06-09-2009 03:46 PM
CJ5 vs cj3a flatfender. Which is better? Renegade_Rick Jeep CJ Forum 12 08-14-2008 08:31 PM
Where buy CJ3A radiator? farmjeep50 Jeep CJ Forum 1 07-17-2008 07:57 AM
CJ3A Wiring PaulS Jeep CJ Forum 1 06-19-2008 10:42 AM
