CJ3a brake drum removal - Page 2 - JeepForum.com
post #16 of 17 Old 10-16-2013, 04:56 PM
Whit
1950 CJ3A
Originally Posted by stinsonj View Post
Thanks for everyones help, i really appreciate it. turns out i was getting worrie about nothing. Everything came apart really easily with no special tools in about an hour once i figured it all out. For anyone that plans on removing the brakes in the future, here are the steps i took to get the job done (sorry i dont know the terminology for everything):
1)Remove the hub cap (about (6) 1/2" bolts
2)Remove the locking hub assembly
-is about 2" thick and can easily be pried off with a skrew driver or just pulled off if you are luck
3) Remove the outer axel nut
-If you have the special nut tool, great, if not, you might be lucky enough to find that someone has already put grooves in the nut, enableing you to use a flathead skrewdriver and some light taps of a hammer to remove.
4) Remove the washer and inner axel nut in the same fashion as the outer nut
5)The whole hub should now easily slide off the axel, at least mine did
When i did mine, i removed the brake drum before removing the hub, but come to think of it, it probably would have been a lot easier to remove the drum and the hub all at once. As long as you back the shoes off all the way, everything should slide right off. If it doesnt, tap it with a hammer a couple of times. Once the hub and drum are removed, everything else just unbolts and the new brakes should bolt right up.
Another minor problem i had was that the brakes were ever so slightly too big for my stock wheels. At least on my wheels, there is a little lip on the inside that wsa barely catching the brake, not allowing it to go on all the way. I beat on it with a big ole hammer for about 2 min to flatten it out and now everything fits perfect Hope this helps anyone that is thinking of doing the same swap
Just followed your simple instructions on my CJ3A... Worked just as you say. Thanks for the simplified description.
1950 Willys CJ3A, all stock except 33" BFG M/T
2011 black WK2, 5.7L Hemi
Whit is offline
post #17 of 17 Old 10-17-2013, 02:55 PM
bkeese
1949 CJ3A
The biggest problem I had was 3 wheels were right hand thread and 1 was left. After I figured that out it was down hill.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
CJ3a steering and brake issues stinsonj Jeep CJ Forum 4 11-25-2009 09:18 PM
emergeny brake foot pedal removal and brake fluid removal???? sail78385 Jeep CJ Forum 1 04-03-2009 06:20 PM
CJ 5 Front Drum removal Krackalacka Jeep CJ Forum 4 01-25-2009 11:40 AM
Front drum removal on 66 CJ5 jeeprookie47 Jeep CJ Forum 4 09-10-2008 09:00 AM
yj brake booster on a manual drum brake cj5? 77 renegade Jeep CJ Forum 2 02-12-2005 05:17 PM
