cj3a/b wrangler spring swap... - JeepForum.com
post #1 of 4 Old 07-20-2007, 04:41 PM Thread Starter
redjeep669
2009 JK Wrangler
what exactly is involved in converting an older cj3 to use wrangler leafs? i've been searching through the web and pretty much found that the wrangler leafs are much longer and the shackle locatons need to be moved. is this the rear only or both? or is it going to be more of a figure it out as you go type of thing? thanks for any info.
redjeep669 is offline
post #2 of 4 Old 07-20-2007, 06:02 PM
jeepskate
You'll need to figure it out. You'll need to replace & relocate the spring hangers and the shackle hangers both front & rear.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 4 Old 07-20-2007, 08:44 PM
earlycj5
It's on a CJ-5, but I'd wager that it's close enough to what you need to do that it'd be useful.
http://earlycj5.com/tech/SpringsShocks/yjconv/index.php
regards,
Sparky
earlycj5 is offline
post #4 of 4 Old 07-21-2007, 11:01 AM Thread Starter
redjeep669
2009 JK Wrangler
hmm. i bet that is pretty close. i'll have to look into that more. the only thing i found was that there used to be a bolt on kit (4 wheel plus parts or something. no longer avail) and that you had to be careful as to perch location.
Cj3a Milspec Jeep CJ Forum 3 03-08-2011 05:44 PM
cj5 cj3a floor pan tell me what it is baystrucksalvag Jeep CJ Forum 5 06-09-2009 02:46 PM
Wrangler leaf spring swap question jollyroger Jeep CJ Forum 1 12-22-2008 06:41 AM
CJ5 vs cj3a flatfender. Which is better? Renegade_Rick Jeep CJ Forum 12 08-14-2008 07:31 PM
CJ3A Alternator Swap? sms888 Jeep CJ Forum 5 07-23-2008 08:02 PM
