CJ2A Axles - JeepForum.com
post #1 of 7 Old 08-02-2010, 08:35 PM Thread Starter
fully81
CJ2A Axles
I am starting to rebuild a CJ2a jeep and need to know what the widest axles I can put under it and where I could get some. I am looking to lift the jeep and widen it.
fully81 is offline
post #2 of 7 Old 08-02-2010, 08:37 PM
BamaLonghorn
1980 CJ7
I have always wanted to build up a CJ2a. What are your plans for it?
Originally Posted by sparkchaser View Post
You must be new here. A good 90% of arguments on Jeep Forum are built on gross generalizations and a framework of logical fallacies that fall apart under the slightest bit of scrutiny.
2001 Jeep Wrangler Sport - SOLD
1979 Jeep CJ-5 - Sold
1980 Jeep CJ-7
BamaLonghorn is offline
post #3 of 7 Old 08-02-2010, 09:30 PM
JeepnBlake
How wide do you want?
1 ton Dually width?
Rockwell 2.5 ton width?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #4 of 7 Old 08-03-2010, 12:50 AM
Eman
1 ton Dually width?
OMG Do a Rockwell build!
*** what size of tires are you looking for? highway driving? or just wheelin?
89' Jeep Cherokee Laredo - Rough Country 4.5" Full leaf pack.
55' 4x4 Willys Wagon
Eman is offline
post #5 of 7 Old 08-03-2010, 07:51 AM
kickingprop
if you want some slightly wider than what came stock then WT CJ7 axles would be a good place to start...shouldnt require outboarding or anything other than moving spring perches.
If you want slightly wider than that then Scout or 70's Wagoneer axles would be your next bet.
If you are restoring the 2A and keeping the Dana 18 TCase you'll want to find an offset rear axle as well. Quadratrac CJ7's and Waggys had this offset as well as a few others
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #6 of 7 Old 08-06-2010, 08:58 AM Thread Starter
fully81
I just want something slightly wider and don't have to do much modification with the frame cause the stock cj2a's are so narrow. About how much wider are the CJ7 axles? We are also putting a small block 350 in it using the turbo350 tranny and hoping to use the chevy transfer case as well. It is mostly gonna be used for occasional road driving and a little offroading. We plan on doing a like a 2 inch suspension lift and then will probably have to add another inch with a body lift to fit the chevy transfer case and tranny underneath
fully81 is offline
post #7 of 7 Old 08-06-2010, 09:18 AM
kickingprop
you arent gonna squeeze a 350/TH350/NP203(or 205/208) combo into a CJ2a... You would have a rear driveshaft that is 3 inches long... if you want to run a 350 (which I think is wayyyy too much engine for a 2a) you will have to run a manual tranny, probably an SM420 or SM465 mated to Dana18/20/300. You COULD fit that combo under a 2a if you planto stretch the wheelbase about 10-20inches...
1985 CJ7 Project
cj2a for me! jeep795 Jeep CJ Forum 25 11-25-2012 03:15 AM
'48 CJ2A help Jreedpete Jeep CJ Forum 1 07-17-2009 05:32 AM
'46 CJ2A help LouisCali Jeep CJ Forum 2 05-28-2008 02:21 PM
48 cj2a danthman Jeep CJ Forum 14 03-13-2008 02:42 PM
47 CJ2a Fireman Dan Jeep CJ Forum 5 05-09-2007 10:25 PM
