CJ10 Half Top and Doors on a CJ7 - JeepForum.com
post #1 of 5 Old 03-13-2009, 12:13 AM Thread Starter
81cj7id
Will this work? I dont know much about the cj10 but it looks wider. Asking because i found a great deal on a top and doors and would like a half top on my jeep. Thanks.
81cj7id is offline
post #2 of 5 Old 03-13-2009, 12:36 AM
Ford_Prefect
I would just ask for a measurement on the top... IE side to side, and from the edge of the door to the rear of the top... That should give you enough info to get a basic understanding. Then if you think it will work but are not sure just drive the jeep down to pick up the top, put it on, if it does not fit don't pay the guy...
Ford_Prefect is offline
post #3 of 5 Old 03-13-2009, 12:55 AM
jscherb
Yes, the doors and top will fit but the bottom rear edge of the CJ-10 top will need to be notched to rise over the top rail of the tub, and you'll need to make some sort of bulkhead to fit between the rear bottom edge of the top and the floor. Kind of like a Scrambler bulkhead, but the CJ-10 top is 1.5" shorter in length than the Scrambler half-cab, so the Scrambler bulkhead won't meet up properly with the bottom of the CJ-10 hardtop. Also the Scrambler bulkhead is raised about 3/4" across the top edge inside the tub and the CJ-10 hardtop expects a mounting surface even with the top of the tub.
I can probably give you whatever other details you need, since I've adapted a CJ-10 hardtop to my Wrangler pickup.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #4 of 5 Old 03-13-2009, 06:52 AM
BriansCJ
1994 XJ Cherokee
The doors will fit.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #5 of 5 Old 03-13-2009, 04:05 PM Thread Starter
81cj7id
Ok so everything should fit with a little work. Thanks.
81cj7id is offline
Should I make full doors into half doors? NWA_CJ7 Jeep CJ Forum 20 04-25-2011 06:41 PM
safari doors vs half doors JeepnBlake Jeep CJ Forum 3 04-04-2008 08:10 PM
YJ half doors on a '76 CJ-7 burchdog32 Jeep CJ Forum 1 02-15-2008 11:02 PM
Will YJ half doors fit CJ7? dand98 Jeep CJ Forum 2 08-22-2006 08:31 PM
Supertop half doors vs 1/2 doors CJ5 rcsutton Jeep CJ Forum 2 05-12-2004 11:10 PM
