CJ YJ Tub Body Swap Link Listing - JeepForum.com
post #1 of 46 Old 12-31-2007, 10:05 PM Thread Starter
Floridazed
Floridazed's Avatar
1980 CJ7
Yes it can be done.
Those interested in swapping your tub for a rust free...
Free research!
Here are some links I found researching the subject on other sites than jeepforum.com
Add new links if more.
http://www.cjoffroad.com/forums/topic.asp?TOPIC_ID=462
http://www.cjoffroad.com/writeup.asp?WU_ID=24&noAdd=1
http://www.selil.com/web/slideshows/...J_Wrench_Fest/
http://www.geocities.com/cdncj7/tubswap.html
http://www.geog.ucsb.edu/~pingel/jeepblog/
On this one, click to next page after reading. 3 or so pages/
http://www.inajeep.com/cjbuildup/mybuildup7.asp
http://forums.4wd.com/forums/showthread.php?t=13792
http://myweb.cableone.net/wdohrn/tubswapnew.htm
cj dash on YJ (just plain interesting)
http://jeep.off-road.com/jeep/articl....jsp?id=261303
Andy
_______________
1980 CJ-7 : 151GM : Stock : In process of restoration (always constant, and something to do.)
Floridazed is offline
post #2 of 46 Old 12-31-2007, 10:16 PM Thread Starter
Floridazed
Floridazed's Avatar
1980 CJ7
sorry, how could I forget...
http://www.jeepskate.net/index.html
Andy
_______________
post #3 of 46 Old 01-01-2008, 06:16 PM
CrazyHorse6
1979 CJ7
CJ YJ Tub Body Swap
Great post above - in fact I put a YJ tub onto a CJ frame myself. Very easy to do with the only real mods are to either flip the gas tank around and run new lines or cut a new gas cap hole on the other side of the tub, and make some adjustments to the airflow where the windshield mounts onto the top the of cowl. I simply cut two rectangular vents to push air to the occupants and did away with the defrost vents throught the bottom of the windshield frame. I live in Georgia and have not seen "frost" in years.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #4 of 46 Old 01-01-2008, 08:53 PM Thread Starter
Floridazed
Floridazed's Avatar
1980 CJ7
Question: Do you buy YJ or CJ body mounts? Can you use CJ bolts, or are they not same length?
Question: Can I use CJ rollbar?
Andy
_______________
post #5 of 46 Old 01-01-2008, 09:43 PM
sanmiam
sanmiam's Avatar
1983 CJ7
I have asked these before, so let me give this a shot:
1) Body mounts are the same (correct me if I am wrong) Personally I would buy CJ mounts.
2) The bolts are different thread pitch between the YJ and CJ tubs. I have not been able to find the exact specs so I can let you know in a month and a half or so when I swap mine on.
3) CJ rollbar will bolt up to the YJ tub.
As stated - this is what I have found, not from actual experience.
sanmiam is offline
post #6 of 46 Old 01-01-2008, 09:48 PM
jeepskate
1) Some of the YJ body mounts are larger diameter...you can use them if you enlarge the holes in your frame mounts...did this on my first swap.
2) Some of the YJ bolts are larger diameter.
3) Yes, the late-'79 CJ to '95 YJ bars are readily interchangeable (except for the windshield support bars on the YJ). '76 - early '79 will work as well provided you drill the holes in the sides of the tub to mount it.
Okay...in the links you posted, I actually helped Selil do his swap...let's see who can pick me out of the pictures...
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #7 of 46 Old 01-01-2008, 10:38 PM Thread Starter
Floridazed
Floridazed's Avatar
1980 CJ7
looks like you used new mounts and bolts. I am assuming its YJ mounts and bolts. Just enlarge the holes in the frame mounts on the CJ frame. Correct?
Question: on moving the mounts in front of the rear tires, just grind off...move...and weld. You can use the same mounts?
Also, If I had to guess, you are the dude with the spider tattoo on your arm.
Andy
_______________
post #8 of 46 Old 01-01-2008, 11:21 PM
bjf498
bjf498's Avatar
1983 CJ7
I would just use a kit for a cj-7 i think yj's have two grille mounts
you don't have to do it that way you can just leave the cj mount where it is and stick a nut and washer in the support channel on the yj tub
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
post #9 of 46 Old 01-02-2008, 12:49 AM
jeepskate
1) Yes, I used new mounts and a MORE body lift for a YJ and enlarged the requisite holes in the frame mounts. IIRC it's just the 6 mounts along the sides under the rocker panels.
2) Like bfj said, you can just stick a nut & washer in the support channel...did that on my second swap.
3) Nope, that's my buddy Anders...he did a lot of the recent custom fab work on my Scrambler project. I'll narrow it down for ya'...I'm one of the 3 guys in this pic:
post #10 of 46 Old 01-02-2008, 03:32 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I have a bunch of things listed here for you to do to convert a YJ body.
http://www.certifiablejeep.com/yello...dproject22.php
The whole write-up is about restoring a Jeep with a YJ body to look like a CJ...
Since then, I have 2 more conversions... A lot of what TO do and what NOT to do.
http://www.certifiablejeep.com/freejeep/freejeep28.php
http://www.certifiablejeep.com/curti...urtisjeep1.php
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #11 of 46 Old 01-29-2008, 08:25 PM Thread Starter
Floridazed
Floridazed's Avatar
1980 CJ7
OK tub swap gurus and general purveyors of knowlege...
New situation regarding a YJ swap....
Usually people have a YJ windshield and they just have to drill a hole 1" over on the CJ dash to fit the tie down knob bolt. You see the whole when the windshield is down.
Well, I have a brand new windshield for a CJ (from jeepglass.com)
The windshield tiedown bracket lines up with the hole on the dash, but there is no hole in the tub rail to screw in the tiedown knob.
What should I do? I obviously need to drill a hole in the tub rail, but do I need to weld a washer in behind it? Or can I just drill the hole big enough and just screw the knob through the top rail? Would it need to be tapped?
Thanks
Andy
_______________
post #12 of 46 Old 01-29-2008, 08:42 PM
HighCountry
That sounds serious! Without going out and folding down my windshield, I 'seem' to remember there being a threaded nut somehow retained below the surface of the sheet metal. There is a LOT of pressure on those two bolt/knobs from vibration and such!
Bruce
HighCountry is offline
post #13 of 46 Old 01-29-2008, 08:48 PM
84MSRB
I'm thinking about doing the same thing there as on that 3rd set of bady mounts- just take a small piece of steel and weld in nut- one of them "captured nuts". Then cutting/sawzalling/removing the portion of the cowl where the holes don't line up and weld them in. It's gonna get covered by the CJ dash- that I'm assuming you're using.
jeepskate- I'm guessing you're trying to throw us all off. I'm going to vote for the guy in the background with the socks and sandals.
1984 CJ7 Mud Slingin Rust Bucket
90 YJ tub
Ford Mutt 5.0( 69 block, 89 EFI)
84MSRB is offline
post #14 of 46 Old 01-29-2008, 09:19 PM Thread Starter
Floridazed
Floridazed's Avatar
1980 CJ7
Sucks... I dont have a welder. Any other options?
Or should I just call a welder over?
Andy
_______________
post #15 of 46 Old 01-29-2008, 09:57 PM
molsenice
1964 CJ5
mmmmm - I count 4 guys in the pic, unless you dont count the glare off that WOMANS HEAD in the background
molsenice is offline
Listing alert: Narrowed Dodge D60 front housing PavementPounder Jeep CJ Forum 0 01-28-2010 10:35 AM
Cj-5 body swap? sailorjeep3 Jeep CJ Forum 0 02-01-2009 07:08 PM
look at this craigslist listing neatocj Jeep CJ Forum 6 08-20-2008 08:47 AM
Body mount for yj body swap cjheven Jeep CJ Forum 6 05-04-2006 10:15 AM
'76 CJ-5 body swap posatyvo Jeep CJ Forum 0 10-28-2001 10:00 PM
