CJ or YJ springs in the rear of a CJ7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ or YJ springs in the rear of a CJ7
Introducing the Quart Crate...JK Front Axle TrussPoison spyder items @ oconee off road 706 534 9955
Unread 08-11-2014, 06:31 PM   #1
BlueRubiconrich
Should I use CJ or YJ springs in the back of my 86 CJ7? I wheel it. but looking for better wheel travel. What do you think?
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline   Reply With Quote
Unread 08-11-2014, 11:40 PM   #2
RenoF250
I think CJ and YJ rear springs are the same. The YJ fronts are the same width as the rear and the CJ fronts are narrower.
RenoF250 is offline   Reply With Quote
Unread 08-12-2014, 03:41 AM   #3
VooDoo2
1978 CJ7
YJ springs are longer so you may need to move the hangers back a little. I run YJ OME front and rear and moved the hangers both ends
VooDoo2 is offline   Reply With Quote
Unread 08-12-2014, 08:07 AM   #4
Jim1611
Jim1611's Avatar
Are you certain the rear YJ springs are longer? If I understand you correctly.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote
Unread 08-12-2014, 09:04 AM   #5
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The YJ and CJ rear springs are the same length.
The YJ fsprings are about 1-1/2" longer than CJ front springs.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 08-13-2014, 07:53 PM   #6
VooDoo2
1978 CJ7
Sorry, my mistake, the YJ rears are the same but my shackle hanger was longer hence it sticks back an inch longer than the stock hanger (Crabtree FTW!!)
