cj to yj spring conversion + shackle reversal = ? - JeepForum.com
post #1 of 16 Old 02-25-2013, 09:58 PM Thread Starter
Alex77cj7
1977 CJ7
Okay so ive been trying to do some research and cant find much on doing a yj spring conversion and shackle reversal at the same time.. I have a soa on my cj7 with stock springs and i was wanting to convert to the yj springs. I know if i was doing a regular spring conversion id have to re locate my hangers but instead of relocating the fronts couldnt i just do a shackle reversal? anyone have this combined set-up?
Any help is greatly appreciated!
Thanks,
Alex.
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline
post #2 of 16 Old 02-25-2013, 10:06 PM Thread Starter
Alex77cj7
1977 CJ7
couldnt i just buy a yj shackle reversal kit? wouldnt that take care of the mounts and everything?
Thanks.
post #3 of 16 Old 02-26-2013, 02:44 AM
skizriz
1978 CJ7
From what I read, SOA and a shackle reversal don't mix well.
Sent from my iPod touch using JeepForum
skizriz is offline
post #4 of 16 Old 02-26-2013, 06:21 AM Thread Starter
Alex77cj7
1977 CJ7
Ohhh okay. Well thank you. Are you using a kit or what when you do your yj spring swap?
post #5 of 16 Old 02-26-2013, 07:11 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The YJ springs are a little over an inch longer than stock front CJ springs.
I think you will need to either move the hangers, or buy different hangers that compensate for the longer springs.
I know opinions vary widely on the reverse shackle. My research turned up too many negatives, so I ruled it out.
Matt
Matt1981CJ7 is offline
post #6 of 16 Old 02-26-2013, 07:33 AM
rd94yj
I vote no on the shackle reversal!
But all in on the 2.5in wide spring swap!!
Post pics of that spring over!
What axles are you running?
94 YJ 60/14 bolt 4.0 ax15 Dana 300
88 YJ 60/14 bolt AMC 360 nv4500 np241
rd94yj is offline
post #7 of 16 Old 02-26-2013, 08:26 AM Thread Starter
Alex77cj7
1977 CJ7
Stock narrow track amc 20 / Dana 30. For now atleast.
post #8 of 16 Old 02-26-2013, 01:48 PM
skizriz
1978 CJ7
Matt is on the right track. The front shackle hangers are too narrow to use, but rear CJ shackle hangers can be used for the front. They need moved one hole forward, where the crossmember rivit is. The rivit will need to be removed. On my new frame I set it up to be able to mount the hangers where needed as I wasn't sure what springs I would end up with.
skizriz is offline
post #9 of 16 Old 02-26-2013, 02:04 PM
Matt1981CJ7
1981 CJ7
Or, as I said earlier, you can buy 2.5" wide hangers and shackles, that will move the pivot point forward and allow you to use the same mounting holes.
Crabtree Tool and Die is a sponsor of this forum. Jim makes a beautiful set of hangers and shackles for the YJ conversion. I only used Jim's shackles, because I already had my hangers in place.
Matt
post #10 of 16 Old 02-26-2013, 02:11 PM Thread Starter
Alex77cj7
1977 CJ7
Crabtree Tool and Die is a sponsor of this forum. Jim makes a beautiful set of hangers and shackles for the YJ conversion. I only used Jim's shackles, because I had already my hangers in place.
Matt
How much does the set usually run?
post #11 of 16 Old 02-26-2013, 04:01 PM
skizriz
1978 CJ7
I didn't think he was making the hangers any more?? Just the shackles.
No doubt they are top quality hangers. If you can still get them.
http://www.jeepforum.com/forum/f241/...ngers-1128606/
http://www.crabtreetool.com/jeep%20products.html
skizriz is offline
post #12 of 16 Old 02-26-2013, 04:07 PM Thread Starter
Alex77cj7
1977 CJ7
Thanks guys!
post #13 of 16 Old 02-26-2013, 04:10 PM
Matt1981CJ7
1981 CJ7
skizriz,
Jim reconsidered his decision to discontinue the hangers when half the forum threw a fit.
So he bumped his pricing a little, and is still making them.
Well worth the premium price, IMO.
Matt
post #14 of 16 Old 02-26-2013, 04:20 PM
skizriz
1978 CJ7
Originally Posted by Matt1981CJ7 View Post
skizriz,
Matt
I've never seen them in person, but they sure do look sweet from the pictures I have seen.
Glad to hear he reconsidered.
skizriz is offline
post #15 of 16 Old 02-26-2013, 07:15 PM
83vert
1982 CJ7
I have a set and they are a quality piece that's for sure
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
