CJ And YJ frames - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ And YJ frames
Engo winches available at www.rockridge4wd.com! Free shippRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 08-23-2014, 05:15 AM   #1
CJFF29
1979 CJ7
CJ And YJ frames
I have had a hard time finding a replacement CJ frame for my build and mine would take quite a bit of work to get fixed.... My question is.... What are the major differences between CJ and YJ frames besides the body mounts.
They aren't a concern since I have a YJ tub to replace my rotted out CJ tub. Would I be better off building a YJ and using the CJ dash and fenders?
'79 CJ7 360/T150/Dana20/AMC20 rear/Stock Suspension (for now)/30x10.5x15/Rusted A$$ Tub (YJ tub swap in progress)
CJFF29 is offline   Reply With Quote
Unread 08-23-2014, 09:11 AM   #2
BlueRubiconrich
yes, unless you buy a new aftermarket CJ frame.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline   Reply With Quote
Unread 08-23-2014, 09:12 AM   #3
martinfan
Cost wise I would say yes. Easier to find a YJ frame than a good CJ frame. And if your looking for toy or driver and not a restoration project really wouldn't matter. Not a lot of difference between the two but enough to create some work wider front spring, dash / defrost different, grill mounts a little different. NOTHING that can't / hasn't been done. Good luck have fun.
martinfan is offline   Reply With Quote
Unread 08-23-2014, 09:46 AM   #4
only in a jeep cj
But if your starting with a CJ,the axles won't bolt up, and you'll need YJ springs as the mounts are welded in on the front and the eye to eye distance is a little longer. Transmisdion mount will be off too. In the end, you'll have a YJ with a CJ dash and front clip. The CJ grill will need a large notch cut out of the lower left corner to clear the now higher steering box. The grill mount will be off too.
Use a CJ frame ..
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Unread 08-23-2014, 09:57 AM   #5
CSP
The YJ frame rails are 4" further apart than a CJ, front and rear.
CSP is offline   Reply With Quote
Unread 08-23-2014, 01:52 PM   #6
CJFF29
1979 CJ7
Ugh, back to the search for a CJ frame I guess.
Unread 08-24-2014, 12:13 AM   #7
JohnnyRotten
1978 CJ5
Try TDK for a frame. I picked one up 2 years ago. Its still sitting in the garage...finally primed. Eventually I will get it done. Do not buy it from TDK though. Try 4WD first. The shipping from 4WD Hardware was $300 less than from TDK. You call and order from 4wD and TDK will call you to take your order. I had mine in about 2 weeks.
JohnnyRotten is offline   Reply With Quote
Unread 08-24-2014, 08:03 AM   #8
holliewood61
1981 CJ7
^^ This. I did a build a few yrs back off a TDK frame. The quality is amazing, body and engine mounts were dead on. You can have them set the cj frame up for the yj tub so you dont have to move any body mounts. Its more expensive than a used frame of course, but thats because its worth it.
08 WK bone stock
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline   Reply With Quote
Unread 08-24-2014, 10:45 AM   #9
RenoF250
If you are using a YJ tub it sounds like a YJ frame will be cleaner and less work.
RenoF250 is online now   Reply With Quote
Unread 08-24-2014, 09:54 PM   #10
only in a jeep cj
Until he tries to install the CJ axles and CJ grill onto that YJ frame. He'll probably need a YJ gas tank too....and YJ fuel and brake lines.
Ed
Unread 08-24-2014, 10:17 PM   #11
RenoF250
Fixing that seems easier than moving all of the body mounts for the YJ tub.
Unread 08-24-2014, 10:24 PM   #12
holliewood61
1981 CJ7
Only 1 body mount on each side of a cj frame needs to be moved to use a yj tub.
08 WK bone stock
60 CJ5 tore down
Unread 08-24-2014, 10:29 PM   #13
only in a jeep cj
Only 2 on each side don't line up and for one set, there is holes that do line up so a nut plate slides in and those are done. For the other two (the rear crossmember), they're off by 3/4" and a simple drill and tap is all that's needed. I promise you that is way easier than moving perches on both axles, notching the grill to clear the power steering box, extending the front grill frame mount, and gathering and installing/ swapping over to all the other small details that will be effected by the frame swap (engine mounting/ trans mounting/ sway bar/ fuel and brake lines/ gas tank placement, etc). Ive done YJ tub swaps onto CJ frames....its the way to go.
Ed
Unread 08-25-2014, 10:23 AM   #14
chris989604
1980 CJ7
What year are you looking for?
chris989604 is offline   Reply With Quote
Unread 09-03-2014, 07:28 PM   #15
CJFF29
1979 CJ7
Prefer an '82- '86 frame
