cj yj frame - will it work? - JeepForum.com
post #1 of 9 Old 05-02-2010, 09:23 PM Thread Starter
tbramich
my friend has a 85 cj7 and the frame is about rotted to the point of not usable but we still go wheeling until that day comes.
i know where i can get a 93 yj frame from with no rust for a good deal, will it work?
i have a 95 yj and it looks really close so thats why im asking.
today my buddy & i were wheelen and when he gt stock in the mud i had to give him a hard yank to get him out and i tore off the front bumper and the frame a few inches back, so now we are kind of in rush to find a replacement inexpensively. i know he cant really afford a new one at $1700, his budget is more in the $100-300 range.
tbramich is offline
post #2 of 9 Old 05-02-2010, 09:49 PM
rugz31
1976 CJ7
anything can be made to work with enough work, time, and money.
however, i think this should work fairly easily. someone correct me if i'm wrong.
rugz31 is offline
post #3 of 9 Old 05-02-2010, 10:22 PM
beachedjeepyj
I'm pretty sure it will work, i don't know how straightforward it will be but I've seen a yj tub on a cj frame so i don't see why it wont work the other way.
http://www.jeepforum.com/forum/f8/cj...isting-501837/
Check this link out!
Edit:
I also believe that the mounting the the grill might take a little modification as the cj's front is shorter than the yj's but im pretty sure the issue is addressed in a yj to cj grill swap thread.
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
post #4 of 9 Old 05-02-2010, 11:08 PM
only in a jeep cj
It will "work" untill you go to swap in the drivetrain. The rear can have the perches cut and moved out, but the front will be another challenge. I would find a CJ frame in the 82 to 86 years or cut and add the correct shock towers for pre 82.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #5 of 9 Old 05-03-2010, 03:48 AM Thread Starter
tbramich
thanks guys, i'll pass all of this on to him.
tbramich is offline
post #6 of 9 Old 05-03-2010, 05:04 AM
alex211
1995 XJ Cherokee
I'd would do it, then you also get the wide leaf springs up front.
95 xj bone stock for now
alex211 is offline
post #7 of 9 Old 05-03-2010, 06:49 AM
bigredisb
1979 CJ7
Depending on the drive train you might have to come up with some cutoms changes to the trans crossmember as well. I am swapping my 79 frame for a 84 frame and I have sound quite a few changes between the two frames. Especially the crossmember. Like Alex211 stated plan on buying front springs as well since teh width is different between the two frames.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #8 of 9 Old 05-03-2010, 07:52 AM
rugz31
1976 CJ7
as long as you swapped the cj drivetrain mounts, etc. it should be a fairly straight forward swap
rugz31 is offline
post #9 of 9 Old 05-03-2010, 02:59 PM Thread Starter
tbramich
he said his is the "wide axle" version from the factory, what ever that means & he thinks the springs are a direct conversion over. but im sure we can handle any minor things like that that come up.
tbramich is offline
Frame Work jeepjeepwhat Jeep CJ Forum 5 01-11-2010 07:28 AM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 08:44 PM
frame work uglydoug Jeep CJ Forum 1 01-01-2004 07:47 PM
CJ7 needs frame work/maybe lift GreenCJ7 Jeep CJ Forum 5 02-18-2002 09:40 PM
