CJ wouldn't start today????then fired right up - JeepForum.com
post #1 of 11 Old 08-02-2010, 06:33 PM Thread Starter
OlivergreenCJ7
Got back form running an errand today and I turned the jeep off to go open up my garage doors. When I went back to start the jeep nothing. No volts, no clicking, nothing electrical worked. I got my volt meter out check the volts at the battery 12v+, check the volts on either side of the starter solenoid 12+v checked volts with the key at the on position and had less than 4 V at the solenoid. Checked my connections everything was clean and tight. Went to check the key again and it fired right up. Any guesses? Could it be a loose ignition switch, bad solenoid, starter, etc. I had the battery load tested at is was good to go. I turned the jeep off and on a couple times to try to recreate the power out, but no luck.
thoughts?
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline
post #2 of 11 Old 08-02-2010, 06:52 PM
Trapshooter
You did say "nothing electrical worked", does that mean a total electrical failure or just that the jeep wouldn't start?
How hot was it there today?
I'd start with checking the main ground connection if it was indeed a total electrical failure.
Good luck.......
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 11 Old 08-02-2010, 06:56 PM
jkoch8819
Are you sure you did not have it in gear?
All Jeeps are Jeeps, But built Jeeps are Real Jeeps... Round or Square
**The Only Thing Snow is good for is to check if the Jeep is Leaking**
jkoch8819 is offline
post #4 of 11 Old 08-03-2010, 06:46 PM Thread Starter
OlivergreenCJ7
The gear situation wouldn't be a problem on a 79 CJ7, but yes it was a total electrical failure. Nothing worked... not even my winch hooked up straight to the battery worked. After checking for loos connections and some choice swear words it fired right up. It wasn't to hot or anything, but I'm not a jeep engine Would it be possible for a loose connection inside the starter solenoid? Fired right up today, but I would like to have a answer for the frustration I had yesteday. If you guys can think of anything please chime in.
post #5 of 11 Old 08-03-2010, 07:13 PM
philodox
This just happened to me. I have an '85 CJ-7. Turns out the computer was fried. I continued using it sparringly until eventually it was DRT... Turned out I needed to replace the entire wiring harness and computer. I was lucky to find a complete wiring harness for an '85 to include the computer to swap it out.
I know your '79 doesn't have a computer, wish I could help point you in the right connections.
FYI, starter solenoid doesn't carry voltage unless you are cranking the engine.
-Jon
philodox is offline
post #6 of 11 Old 08-03-2010, 07:28 PM
sireland67
My neighbors 74 Ford truck did almost the same thing last week.
Would not start, battery showed good juice.
We cleaned the battery terminals and no help, which were pretty clean to start with.
Turned out that the battery had a shorted plate in it.
sireland67 is offline
post #7 of 11 Old 08-03-2010, 07:51 PM
Trapshooter
This comment speaks volumes. It has to be the battery.
My 401 build:
post #8 of 11 Old 08-04-2010, 10:56 PM
egotrp68
1978 CJ5
as silly as it may sound. I was doing some re-wiring the other day and ended up with the same results, nothing, no click and everything metered OK. The positive cable on the battery felt tight, gave it another half turn on the nut and wammo, fired right up.
egotrp68 is offline
post #9 of 11 Old 08-04-2010, 11:12 PM
zeronight
1982 CJ7
batterys can do weird stuff. one time i was riding with a friend of my in his 98neon (nothing ever done to it and this was years ago) we stopped at a car lot in the fall and after 15min of sitting it would not start, lights wouldn't go on, nothing electrical had power, i checked his battery water level and i added half a bottle of aquafina water and it started right up.
zeronight is offline
post #10 of 11 Old 08-04-2010, 11:24 PM
grandcj
I had a similiar problem to this in my '86.a long time ago. I would wiggle some battery wires around it it would start. started fine for a while and did it again. i finally realized it was the ground going from the battery. it looked ok upon casual inspection. the bolt was a bit loose and the terminal toiuching the bolt was kinda rough. clean it and make sure the ground is tight.
grandcj is offline
post #11 of 11 Old 08-05-2010, 07:58 AM
79jeepincj7
1979 CJ7
My 79 did this many times, I'd turn it over and it would just click then i'd lose everything. I changed the starting solenoid and took the starter wire battery wires off, cleaned them up, put new wire ends on them and I never had the issue again.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
battery , battery cable , battery terminal , cranking , solenoid , starter , starting
Good Start/Hard Start/No Start tigercreek Jeep CJ Forum 2 05-25-2010 08:48 AM
fired up new 304 with issues hold24 Jeep CJ Forum 7 04-04-2010 06:35 PM
Need help with wiring alternator, starter, on engine to get it fired up. gmshades Jeep CJ Forum 12 10-12-2009 01:37 AM
My ignition is being stubborn, engine doesn't start in "start" position scrible Jeep CJ Forum 6 10-04-2007 11:04 AM
New (rebuilt) 258 fired for first time no oil pressure Seether Jeep CJ Forum 39 07-04-2007 04:25 PM
