Cj wont stay running! Help! - JeepForum.com
post #1 of 18 Old 11-29-2009, 04:23 PM Thread Starter
trueprimitive
I have a 75 CJ5 with a 258 that i am selling. I had a guy coming to look at it today so I went out this morning and took her for a drive down the road to check everything out since i hadnt driven it in a while. After I got back home i try to start it back up again and it starts every time but will not stay running! Sometmes it will run for 5 minutes and other times it will cut off right after it starts. It dosent sputter or anything just cuts off like you turned the key off. I have a new carburetor and a new fuel pump so it cant be gas. The ignition module and the coil are new on the ignition system along with a new alternator. I cant figure this thing out and i really need to sell this thing. What could it be?
trueprimitive is offline
post #2 of 18 Old 11-29-2009, 04:43 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
What kind of carb is on there? Also, check your fuel filter..
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #3 of 18 Old 11-29-2009, 06:25 PM
nshefbuch
1982 CJ7
not sure but does it have a ballast resistor? my older cj5 does and it would do the same thing when the resistor went bad. if so, simple $2 fix.
nshefbuch is offline
post #4 of 18 Old 11-29-2009, 08:31 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Or like mine, a loose connection at the ballast resistor...
Rick
Cutlass327 is offline
post #5 of 18 Old 11-29-2009, 08:38 PM Thread Starter
trueprimitive
This may sound kinda stupid but......what is a ballast resistor and how do you change it?
post #6 of 18 Old 11-29-2009, 08:47 PM
brian613
1977 CJ5
might have been done but how are your connections to the battery? are they clean and tight?
brian613 is offline
post #7 of 18 Old 11-29-2009, 09:02 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
The ballast resistor is a ceramic rectangular piece (mine is mounted on the firewall on driver side) that is in the wire that goes to the coil from the ignition switch run position. Here's a link, hope it works to show..
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]http://www.autozone.com/autozone/catalog/accessories/accessoriesShelf.jsp?categoryDisplayName=Performan ce&fromType=accessories&fromString=search&parentId =8-10&filterByKeyWord=ballast&currentPage=1&navValue= 100781&categoryNValue=100008&fromWhere=&itemId=781-10&displayName=Ballast+Resistor
Rick
post #8 of 18 Old 11-30-2009, 12:28 PM Thread Starter
trueprimitive
OK i checked the lines to the coil and i dont have a ballast resistor on the line. I have the carter YF carburetor with no fuel filter but i dont think its fuel because it dosnt sputter or anything just cuts clean off. What now?
post #9 of 18 Old 11-30-2009, 01:28 PM
brian613
1977 CJ5
you don't have a fuel filter at all?
brian613 is offline
post #10 of 18 Old 11-30-2009, 01:32 PM Thread Starter
trueprimitive
No i dont have a fuel filter at all.
post #11 of 18 Old 11-30-2009, 02:06 PM
brian613
1977 CJ5
you probably clogged up the fuel jets in your carb.. get someone to try and start it while your looking down the throat and see what kinda fuel spray it has it should be a good strong spray if its not spraying good it can just cut out without sputtering.
you really need a fuel filter on there otherwise your gonna wind up junking that carb......
brian613 is offline
post #12 of 18 Old 11-30-2009, 02:48 PM
Evian
Chances are that it is something really simple like a loose battery cable or wire. Sounds to me your Jeep doesn't want to leave yet.
Evian is offline
post #13 of 18 Old 12-07-2009, 01:04 PM Thread Starter
trueprimitive
Ok I have further diagnosed the problem with the ignition. The motor will stay running until it gets warm but then it cuts off (no sputter or nothing). It will crank every time but will not stay running after the motor is warm. Any ideas?
post #14 of 18 Old 12-07-2009, 01:28 PM
jkoch8819
it is your ignition module.... Or the connector to it... It is a very common problem with stalling and quiting after it gets warm... If you have a auto zone or something they can usually be tested....
All Jeeps are Jeeps, But built Jeeps are Real Jeeps... Round or Square
**The Only Thing Snow is good for is to check if the Jeep is Leaking**
jkoch8819 is offline
post #15 of 18 Old 12-07-2009, 01:30 PM
jkoch8819
Not 100% sure but also check the condenser..
Also after it warms up and not start are you getting any spark?
MC2100 Swap Issues - Will fire, but wont stay running NelsonATC Jeep CJ Forum 4 11-07-2009 11:42 AM
84 CJ7 turns over but wont stay running JohnDeerCJ Jeep CJ Forum 3 02-16-2009 12:14 PM
New 360 starting, wont stay running atom73 Jeep CJ Forum 25 03-06-2008 08:23 PM
My CJ Wont Stay Running Dustin Maschino Jeep CJ Forum 12 03-15-2002 06:37 AM
