CJ won't go in first - JeepForum.com
post #1 of 22 Old 03-03-2014, 04:38 PM Thread Starter
evanbernabei
1981 CJ7
Ill be driving and come to a complete stop and Ill put it in Neutral. When the light turns green Ill go to put it in 1st and it wont go. It won't budge at all. Ill end up having to put it in 2nd and feather the clutch until I pick up enough speed. Any ideas on what could be the problem?
evanbernabei is offline
post #2 of 22 Old 03-03-2014, 05:02 PM
LumpyGrits
How much free play do you have in your clutch pedal?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 22 Old 03-03-2014, 05:39 PM Thread Starter
evanbernabei
1981 CJ7
Prolly around 2-3 inches... It definitely takes a good distance to engage...
post #4 of 22 Old 03-03-2014, 07:00 PM
LumpyGrits
To much-Readjust to 1-1 1/2" at most.
Your linkage maybe shot also.
Check the bellcrank on the firewall for excess slop.
LG
post #5 of 22 Old 03-03-2014, 08:04 PM Thread Starter
evanbernabei
1981 CJ7
If linkage is shot, would it be best to get a new xmission?
post #6 of 22 Old 03-03-2014, 08:11 PM
LumpyGrits
I'm talk'n about the clutch's linkage.
You REALLY must get a copy of the REAL Factory Service Manual and read it.
Haynes and Chilton won't do.....
LG
post #7 of 22 Old 03-03-2014, 08:44 PM Thread Starter
evanbernabei
1981 CJ7
You think it just might need a change of xmission fluid?
post #8 of 22 Old 03-04-2014, 04:53 AM
Mike Romain
If 1st gear is seized, I think it is too late for a fluid change if indeed there is even any fluid left in it.
If it just won't go into 1st, then I would be checking engine and tranny mounts out thinking something has shifted so the gear shifter is binding up.
Mike
Mike Romain is offline
post #9 of 22 Old 03-04-2014, 05:30 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Grinding or the inability to get the transmission to go into the gear indicates a clutch issue.
A "locked" transmission (engine dies/rig won't move) would indicate a shift tower/fork issue, where one gear stays engaged all the time. I for the life of me can't come up with a scenario where you could lock the transmission in two gears, but have it shift normally in all the others.
Transmission goes into first gear, engine revs, but Jeep won't move indicates a sheared first gear/countershaft. It is possible that all the teeth have spit off either one and the countershaft is simply spinning without contacting anything.
There can also be the possibility the scynro dogs (C) have been damaged, or a broken but still in place syncro are jamming the engagement ring, keeping it from sliding over the offending gear.
jeepdaddy2000 is offline
post #10 of 22 Old 03-04-2014, 12:23 PM
Mike Romain
If it goes into 2nd OK like you say and reverse, the clutch is just fine. CJ's have a tendency to eat mounts when off roaded which affects the shifter travel.
Mike
post #11 of 22 Old 03-04-2014, 12:44 PM
LumpyGrits
You NEED to adjust your clutch pedal freeplay first.
When is the last time you checked the transmission oil level?
LG
post #12 of 22 Old 03-04-2014, 01:31 PM
texasdave
texasdave's Avatar
1980 CJ7
Will it shift into first with the engine not running? Go through the shift pattern and if it only does it when the engine is running you have either a clutch problem or an engine mounting problem. If not then you have a xmsion problem.
texasdave is offline
post #13 of 22 Old 03-04-2014, 04:25 PM
turkish6
1982 CJ8
If you have a T4 have you tried pulling the shifter towards second gear before going into first?
turkish6 is offline
post #14 of 22 Old 03-04-2014, 04:34 PM Thread Starter
evanbernabei
1981 CJ7
When the engine is off I can shift it into any gear. Even when its running. Its only happened to me a total of 3 times that this has happened. Every other time it slides into gear great. And this weekend I'm prolly gonna change the xmission fluid. Could it just maybe be a freak thing??? It's been cold as of recent. I don't know if that matters...
post #15 of 22 Old 03-04-2014, 04:37 PM
seabass1858
1983 CJ7
sounds like you need to adjust your clutch linkage underneath where it rides on the clutch fork. its like a 3/4 and 9/16th wrench or something like that. Try this.
seabass1858 is offline
