cj wiring help - JeepForum.com
post #1 of 10 Old 02-12-2013, 10:11 AM Thread Starter
8pitcher
8pitcher's Avatar
cj wiring help
i am getting to wiring my cj5 with a 304 and i have like 8 wires that i cant follow to anywhere. i need help on figuring them out because i have many different red ones and orange purple and such i can get pics later tonight.
i am also not sure on what diagrams to look at because i have no idea on my year. the tub is a replacement and the frame numbers were ground off.
8pitcher is offline
post #2 of 10 Old 02-12-2013, 10:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Start with a picture of the firewall connector.
We can start from there.
I have an 84 CJ harness in my 76 CJ5
John Strenk is offline
post #3 of 10 Old 02-12-2013, 10:31 AM Thread Starter
8pitcher
8pitcher's Avatar
Ok. I have both a 83 cj7 258 harness an another harness from this jeep
8pitcher is offline
post #4 of 10 Old 02-12-2013, 07:13 PM
John Strenk
1976 CJ5
Not sure what you mean?
You have the 83 harness in the jeep right now?
post #5 of 10 Old 02-12-2013, 07:24 PM Thread Starter
8pitcher
8pitcher's Avatar
I have 2 wiring harnesses one from a 83 cj7 and another one from my cj that I am rebuilding.
8pitcher is offline
post #6 of 10 Old 02-12-2013, 07:45 PM
John Strenk
1976 CJ5
So you have no harness in there now and want to install one of the ones you mentioned?
Some harnesses can't be mixed because the plugs are different on the firewall.
You will either have to replace everything or figure out the one you got.
post #7 of 10 Old 02-12-2013, 08:44 PM Thread Starter
8pitcher
8pitcher's Avatar
Sorry I have the 76ish one in there right now and I have about 8 wires that go nowhere and I can't figure out where any grounds are as it doesn't seem like I have any grounds. Sorry I forgot to take pics tonight I was busy with homework and such.
8pitcher is offline
post #8 of 10 Old 02-13-2013, 01:13 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
What ignition are you using?
Matt
Matt1981CJ7 is offline
post #9 of 10 Old 02-13-2013, 03:14 AM
John Strenk
1976 CJ5
Yeah, the 83 and later have a larger plug than the 76 but still will fit in the same hole. Just more circuits but the 80 and later will not fit the 79 and earlier firewall plug. You will have to change the complete wiring in your jeep.
On the other hand, if the wires on the 83 harness are in better shape, then you could remove the wires from the 76 Plug and put in the 83 wires. The terminals are the same and easy to remove.
76 Connector:
And an 80 and later Connection:
Those numbers in the first on correspond to this chart.
post #10 of 10 Old 02-19-2013, 08:34 AM Thread Starter
8pitcher
8pitcher's Avatar
Here is my 76ish firewall connector.
8pitcher is offline
