cj windshield wiper Help! - JeepForum.com
post #1 of 3 Old 10-12-2013, 05:17 PM Thread Starter
tgoodbar
Just got a new cj. The windshield wipers do not work. Where would I begin to diagnose the problem?
tgoodbar is offline
post #2 of 3 Old 10-12-2013, 05:25 PM
AcidLamp
Start at the fuse box and work your way out. Check for a bad or broken fuse. If that's not the case, follow the wires to the switch and check for connections. If you have power at the switch, follow it to the motor and repeat. If everything is good and you've got power to the motor, you likely have a bad one and need to replace.
AcidLamp is offline
post #3 of 3 Old 10-12-2013, 05:29 PM Thread Starter
tgoodbar
Will do. Thanks man
tgoodbar is offline
