CJ W/ TBI 350. Fuel Pump Location - JeepForum.com
post #1 of 9 Old 01-21-2011, 06:51 AM Thread Starter
DT5150
1983 CJ7
i'm wondering if the postion of the fuel pump could cause running issues. mine spits and sputters and doesn't idle consistantly. also lacks some top end power. my fuel pump (from howell, along with the wiring harness) is mounted back by the tank, in front of it, up high. there's that thin little crossmember there where the forward edge of the fuel tank skid and the fuel tank itself bolts up. that's where it's mounted. height wise, it's about even with the top of the tank, maybe slightly above. i think i read somewhere that most guys mount theirs along the frame rail, beside the transfer case, protected by the skid plate. think my running problems could be caused by where the pump is mounted? everything else has been checked and tested, and i mean everything. i'm running out of ideas here...
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #2 of 9 Old 01-21-2011, 07:56 AM
1986cj
Everything I have ever read or seen has been to mount it as low as you can, even Howell's install manual says to mount is along the frame rail by the skid plate.
1986cj is offline
post #3 of 9 Old 01-21-2011, 09:07 AM Thread Starter
DT5150
1983 CJ7
it's been a while since i looked at howell's paperwork, but that's what i thought too...
DT5150 is offline
post #4 of 9 Old 01-21-2011, 09:11 AM
bajaviking
1976 CJ7
I don't run a Howell but my pump is located on the inside of the framerail. I would get the pump down low in a well protected spot.
76 CJ7 6 cyl/t18/Dana 20
05 TJ HP30/8.8 with ARB's Rubicrawler Flatbelly Midarms/3" lift and 35s
bajaviking is offline
post #5 of 9 Old 01-21-2011, 09:14 AM
Alby63
1982 CJ5
The inline pumps are designed to push fuel so they can't draw it from the tank very well. They rely on the natural siphoning to prevent them from running dry, thats why they need to be as close to the tank and as low as possible. I have mine mounted to the bottom of my tank skid plate. I cut the front off an old snapper mower and made the pump it's own skid plate. Try clamping the pump to the bottom of your skid plate, extend your fuel lines and see if that cures your problem. In my pic, it's the red plate.
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stainless mustang SLP exhaust
Alby63 is offline
post #6 of 9 Old 01-21-2011, 10:07 AM Thread Starter
DT5150
1983 CJ7
interesting...
DT5150 is offline
post #7 of 9 Old 01-21-2011, 03:28 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
Mine is mounted up on the front of the crossmember in front of the tank. I had it orginally under the xfr case skid with one of the fuel filters. when i started having starving problems i moved it back to the crossmember and have not had a problem with it since. (plus i can get to it and the filter much easier) the only other problem i had where i thought it was starving turned out to be that if you go from -6 hose (3/8") to the 5/16" fitting on the tank ( i used a clamp insted of brazing on an -an fitting) it would suck air so i had to reduce it down to the 5/16". THat and i crushed the line on top of the tank between it and a body reinforcment. When i dropped the tank you could see the flat spot in it.
Just a few ideas..
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #8 of 9 Old 09-24-2011, 06:44 PM
TiffanysCJ5
i have a '81 cj5 that i recently purchased... and i cannot find the fuel filter...!! i've checked all inside the frame... Nothing. Any suggestions?
TiffanysCJ5 is offline
post #9 of 9 Old 09-24-2011, 06:59 PM
madjeepist
did you look in the factory location? under the hood about 8" from the carb?
madjeepist is offline
Stock fuel psi for electric fuel pump??? TampaXJ Jeep CJ Forum 26 08-30-2010 01:58 PM
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Best location to install Carter 4070 electric fuel pump laparm Jeep CJ Forum 3 11-26-2009 07:14 AM
Fuel Pump - hard to pump by hand? tsujeeper Jeep CJ Forum 3 03-17-2009 03:08 PM
add elect. fuel pump; bypass old pump? Samoa CJ5 Jeep CJ Forum 9 07-12-2004 08:15 PM
