CJ v8 Radiator Question-Purchase - Page 3 - JeepForum.com
post #31 of 38 Old 10-28-2013, 07:56 PM
LumpyGrits
Originally Posted by Matt1981CJ7 View Post
So what you really meant to say was you once saw an aluminum radiator that didn't work well with a shroud, not "most....'.
Thanks for clearing that up.
Matt
There you go again, making a statement about what was never "said"......
Over the years, I have seen about 25-30% of the alum rad. not work with the fitting of a shroud, for the reasons I posted. Along with heavy mod/cutting of the grill recess, for clearance.
And NO, I didn't keep a list of the makers.......
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #32 of 38 Old 10-28-2013, 08:31 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Whatever, Lumpy. I quoted what you "said", numerous times, and you continue to back-pedal. 25-30% isn't "most", it's about 1 in 4.
The truth is, "most" aluminum radiators, that are currently marketed specifically as an OE replacement for a CJ, will use the same (4) mounting holes as the factory radiator and shroud use. That applies to both 2 and 3-row models. The quality may vary slightly between brands, but they are not significantly different, and everything bolts up as it should.
Matt
Matt1981CJ7 is online now
post #33 of 38 Old 10-28-2013, 08:42 PM
LumpyGrits
post #34 of 38 Old 10-29-2013, 04:18 AM
rainjeep
It fit like a glove with my 360. There's about 1-1/2" of clearance with a mechanical fan and fan clutch.
What problems are you having?
Matt
Due to the 3 core being wider now my mechanical fan won't fit anymore and my water pump is in the way. This is a 258 engine. I need to find me a different mechanical fan.
rainjeep is offline
post #35 of 38 Old 10-29-2013, 06:07 AM
lucdog
1980 CJ5
Does the current fan have a spacer behind it?
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #36 of 38 Old 10-29-2013, 03:19 PM
dg6772
Why not look at electric fans.....
Dave in Muskegon
dg6772 is offline
post #37 of 38 Old 10-29-2013, 03:24 PM
rainjeep
B
I'll check for this.
rainjeep is offline
post #38 of 38 Old 10-30-2013, 09:34 AM
turbogus
1978 CJ5
Yep the folks with the inline 6's have clearance issues that us V-8 folks don't have. Although there are some solutions, the options are limited, sorry to say.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
