CJ v8 Radiator Question-Purchase - Page 2 - JeepForum.com
post #16 of 38 Old 09-30-2013, 11:57 AM
AFRd_CJ5
1976 CJ5
I run a Jegs universal aluminum 2 core radiator in mine. Several others around here run the same. Never had an issue with overheating, even on the nasty hot days at the sand dunes.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #17 of 38 Old 09-30-2013, 12:02 PM
AFRd_CJ5
1976 CJ5
Here's another picture a little more "uncovered". You can better see what was cut out of the grill to make it fit, and how it sets in the frame.
'76 CJ5
AFRd_CJ5 is offline
post #18 of 38 Old 09-30-2013, 12:35 PM
SLO_Ken
The Spectra CU583 is a copper 3-core direct replacement radiator. Available at Autozone, Amazon.com, Pep Boys, Summit, and other places, for ~$180.
SLO_Ken is offline
post #19 of 38 Old 09-30-2013, 01:46 PM
bobzdar
Originally Posted by Rollbar View Post
Called Advanced in NM (no Advanced here) and the one for that yr etc was a two core-that is all he could tell me.
Matt-passed on the Ebay link.
Here's the link to the one I put in mine:
http://shop.advanceautoparts.com/web...tor#fragment-2
Look under specs for row quantity.
bobzdar is offline
post #20 of 38 Old 09-30-2013, 09:06 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
The long and short of it:
Short: It depends on the particular radiator.
Lone: Copper absolutely is better at exchanging heat than aluminum....but that doesn't mean every copper radiator is better than every aluminum radiator.
The difference is this: Aluminum is stronger, so the "rows" can be BIGGER.....so bigger rows, or tubes, have more area to exchange heat, so that makes up for its inferior heat exchange properties.
That's why you see places that claim a 2 row aluminum radiator cools as well or better than a 4 row copper; There's probably more water going through the 2 rows in the aluminum because they're so much bigger.
So theoretically speaking, if you built two absolutely identical radiators, the copper one would be better, but the point of aluminum is, you don't have to make it just like the copper one. You can make it with fewer, but larger rows, and it's lighter. Plus, it looks cooler, too.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #21 of 38 Old 10-01-2013, 12:27 AM Thread Starter
Rollbar
1984 CJ8
Hahaha-Thanks guys for all the help/pics.
Question on the bar going to the firewall/frame-Is that tied in to a roll bar or ?
Thanks again everyone,
Jim
<----Click
<---- Click
Rollbar is offline
post #22 of 38 Old 10-01-2013, 05:14 AM
AFRd_CJ5
1976 CJ5
Jim,
Currently no. I needed to get the motor plates in, but didn't have time to move all the ignition stuff under the dash, which is right in the way of where the bars would go. And I am going to redo my whole top rollbar setup (I hate it), so I was waiting until I did that to tie it in.
'76 CJ5
AFRd_CJ5 is offline
post #23 of 38 Old 10-28-2013, 10:54 AM
rainjeep
Originally Posted by Matt1981CJ7 View Post
Jim,
I went with the Champion 3-row aluminum radiator on my 360.
It's worked fine, so far.
Matt
I ordered this same exact 3 core radiator and im having fitting problems with the stock fan. Did you have this problem?
rainjeep is offline
post #24 of 38 Old 10-28-2013, 12:22 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It fit like a glove with my 360. There's about 1-1/2" of clearance with a mechanical fan and fan clutch.
What problems are you having?
Matt
Matt1981CJ7 is online now
post #25 of 38 Old 10-28-2013, 02:59 PM
LumpyGrits
Can't 're-core' an alum. rad. like you can a brass one.
Can't re-solder or do a 'rod-out' with alum like you can with brass.
Most alum. rad's won't work with a shroud.
Why don't you just re-core the brass one, and save some $$$$?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #26 of 38 Old 10-28-2013, 05:20 PM
Matt1981CJ7
1981 CJ7
LG
My shroud bolted right up to my aluminum radiator.
Which models are you talking about, LG?
Matt
post #27 of 38 Old 10-28-2013, 05:34 PM
LumpyGrits
Matt, I don't recall the brand. My CRS has the better of me now........
Your set-up looks very 'clean'.
Wish to god, I could weld like that!
LG
post #28 of 38 Old 10-28-2013, 05:57 PM
Matt1981CJ7
1981 CJ7
Matt, I don't recall the brand. My CRS has the better of me now........ LG
Then how can you claim that "most alum. rad's won't work with a shroud"? Perhaps you should edit that comment.
If the radiator uses the (4) factory mounting holes, then a factory shroud will work as well, since they use the same holes.
There are pros and cons to both aluminum and brass. The user has to decide which are the most important to him. I see no reason to fabricate problems, with either variety, that don't exist.
Matt
post #29 of 38 Old 10-28-2013, 06:08 PM
LumpyGrits
Matt
Some of the alum rad's I have seen, have a large gap between the back of the 'fins' and the front of the shroud. Along with other gaps that make the shroud, all but useless. That 's what I mean, in my "won't work" remark.
LG
post #30 of 38 Old 10-28-2013, 06:57 PM
Matt1981CJ7
1981 CJ7
LG
So what you really meant to say was you once saw an aluminum radiator that didn't work well with a shroud, not "most....'.
Thanks for clearing that up.
Matt
