cj turn signals - JeepForum.com
post #1 of 9 Old 05-03-2011, 03:57 PM Thread Starter
00jeepoff
1982 CJ7
cj turn signals
I have a 82 cj7 most of it is stock on the wiring accept for the brake lights they are LED's that I put in about 6 or 7 years ago. Just a short time ago my turn signal on the right side quit blinking and stays on very dim, but the left side works fine. I have used a test light on the front of the jeep and have the same dim light. The four way flashers work fine also. Any ideas why this has happened?
00jeepoff is offline
post #2 of 9 Old 05-03-2011, 04:20 PM
brian613
1977 CJ5
when you say it stays on dim you mean its not blinking but stays on solid when you turn the blinker that way or you saying that it never shuts off.. ever...
77 cj5 304 v8 np435 twin sticked dana 20 transfer scout dana 44's with 4.88 gears
brian613 is offline
post #3 of 9 Old 05-03-2011, 04:21 PM
TxJeeper20
1982 CJ5
check the connections. my front round turn signal fails to light up unless ur holding the connection at the right angle it may just be corroded
I doubt its right but i tried
Victory Loves Preparation
1982 CJ-5 350TBI/AX-15
1989 Porsche 928 S4
2003 Honda VTX 1300R
2005 Infiniti G35
TxJeeper20 is offline
post #4 of 9 Old 05-03-2011, 04:48 PM
lucdog
lucdog's Avatar
1980 CJ5
Search this CJ section for grounds, you'll find some good info. When the signal light indictator stays on, in the speedometer, it usually means a bulb is burnt out somewere. Not sure on the LED's though.
I asuume when the signal lights are off, the dim light goes out.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 9 Old 05-03-2011, 05:31 PM
twinstickd20
1979 CJ7
The front lights ground through the housing and the grille make sure they are grounded good because that could be the problem
My Build Thread
twinstickd20 is offline
post #6 of 9 Old 05-19-2011, 09:38 PM Thread Starter
00jeepoff
1982 CJ7
Thanks for the info I will try the grounding thing first, and the signal in the rear LED and in the speedo stays lit very dim only when I turn on the right turn.
post #7 of 9 Old 05-20-2011, 03:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Does the speedo turn signal light come on when the head lights are turned on? that would indicate a bad ground for sure.
John Strenk is offline
post #8 of 9 Old 05-20-2011, 07:37 AM
Zaduka31
1983 CJ7
I have the same problem with my Right turn signal it is the only one that will not work and the light on the dash does not come on the parking lamps work fine I added grounds to each light do you think it could be in the wires, I put a meter on the wires at the lights thinging I would get intermittin power but got nothing. Mine is a 1983 cj7
Zaduka31 is offline
post #9 of 9 Old 05-20-2011, 07:55 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
X eleventy billion!!! Ground each one indiviually with a jumper while they are on, it is a quick check that will remove any doubt!
If you don't find the problem to be a ground, it may be in the steering column. I just rewired my entire harness after multiple tries at fixing the old stuff. Now with a new turn signal harness, and all new LED's.. I have the coolest taillights around!!
Good luck and post up your results!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
turn signals flashfludjr Jeep CJ Forum 5 03-23-2009 01:01 PM
turn signals tony dz Jeep CJ Forum 14 09-27-2007 04:35 AM
turn signals - now what? Gummo Jeep CJ Forum 6 09-06-2007 07:29 PM
Turn signals turn on but dont blink JDGordon Jeep CJ Forum 6 02-27-2006 05:17 PM
No turn signals twmattox Jeep CJ Forum 7 12-09-2003 07:03 AM
