CJ tub rebuild - JeepForum.com
post #1 of 6 Old 06-06-2005, 01:56 PM Thread Starter
paraman72
CJ tub rebuild
My tub was refinished when I purchased it, hell for $250 I couldnt asked for more. My only debate was about the the floor boards, when the other person refinished it he put fiberglass on the floor boards. It is pretty sturdy and will probably last quite a long time. It is not as smooth as I would like it to be and it does not have the the drain hole on the drivers side. I have replacement panels for the floor boards but am considering on just leaving the fiberglass in. I plan on herculining the tub and I will have to drill the rain hole out. Should I replace it or leave it be, I just want someone elses opinion who has dealt with this.
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline
post #2 of 6 Old 06-06-2005, 04:52 PM
CJ2a
If it were me I wouldleave it the way it is.. After a few months or even years if the fiberglass starts to break up then replace it with the pannels you have..Also for it not being as smooth as you like, just pick up a small palm sander and sand it down a bit before you herculine the tub and drill the drains
1946 Willy's CJ2a --------------Willy's Jeep Club Member No. 46
Buick 225 V-6 ------------ Orange Jeep Club Member No. 46
Locked rear
33x12.50 15's
I'll add my other rides another day
CJ2a is offline
post #3 of 6 Old 06-06-2005, 04:54 PM
XJ618
If you have new pannels to put in, i would just do it. Build it right, in the long run, you will be happy you did.
XJ618 is offline
post #4 of 6 Old 06-06-2005, 08:06 PM Thread Starter
paraman72
Well one says one way and one the other. If I herculine the tub wont that prevent me from welding in the new panels to bare metal? I have been tossing the ideas just want a big push in th eright direction.
post #5 of 6 Old 06-06-2005, 08:42 PM
Shameless Elmer
83 CJ5
1983 CJ5
My thoughts are... it depends on the condition of the rest of the tub/Jeep.
If the fiberglass was installed over top of the original steel floor boards, assuming the steel was cleaned prior to installation of the fiberglass, I'd leave the fiberglass in place. You probably still have the steel reinforcements on the bottom side of the tub. If you replace the floor pan with the steel ones you already have, you will need to install the reinforcement pieces on the new pans. It is not a small job.
Shameless Elmer is offline
post #6 of 6 Old 06-07-2005, 10:06 PM Thread Starter
paraman72
That was an answer I was looking for, so I will leave them in and sand down the fiberglass. I will hold onto the panels for when I need or when they get in te way.
Amc 20 Rebuild Help! mranth Jeep CJ Forum 3 03-24-2009 04:22 PM
T-176 Rebuild TUPPERCJ7 Jeep CJ Forum 1 03-24-2009 10:56 AM
232 Rebuild glassyjeep Jeep CJ Forum 9 03-17-2009 12:26 PM
To rebuild or not to rebuild? aje3721 Jeep CJ Forum 7 01-12-2008 10:05 AM
258 rebuild 1981BlackCJ7 Jeep CJ Forum 2 01-08-2005 05:05 PM
