CJ Tea Kettle Squeal at idle and low RPMs - Page 5 - JeepForum.com
post #61 of 88 Old 09-27-2013, 12:05 PM Thread Starter
rollmodel1
1979 CJ5
I will be taking the belt off and running the engine today or tomorrow to find out for sure but does anyone think this could be the harmonic balancer?
rollmodel1 is offline
post #62 of 88 Old 09-27-2013, 12:08 PM
MoneypitCJ5
1977 CJ5
It is possible...if the balance ring has separated from the hub.
If it was a 304, I'd say it could also an incorrectly installed timing cover, but I know yours is a 258.
1973 VW Karmann-Ghia first car
2009 Challenger R/T 6MT, Flowmaster, inTune daily driver
1977 CJ5 304, 3MT - under construction
And many in between!
MoneypitCJ5 is offline
post #63 of 88 Old 09-27-2013, 02:02 PM Thread Starter
rollmodel1
1979 CJ5
I'm not sure if the balance ring has seperated and I am assuming your talking about the harmonic balancer right? You'll have to excuse my ignorance I'm just learning haha. I plan to run it belt off hopefully this evening and see if thats the issue. Hopefully it is and I can just order a new one from the parts store, bolt it up and be good to go right?
post #64 of 88 Old 09-27-2013, 03:10 PM
CJ7KAHUNA
Be sure and have your garden hose ready. If its still making the noise it will be the perfect time to use the hose to isolate the source.
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #65 of 88 Old 09-27-2013, 03:21 PM
MoneypitCJ5
1977 CJ5
Yeah the balancer has a steel hub that slides over the crank snout. The actual "balancing" device is usually a hardened rubber ring. The two pieces are fused together when new, but can separate over time.
post #66 of 88 Old 09-28-2013, 07:37 PM Thread Starter
rollmodel1
1979 CJ5
Alright y'all, did the garden hose with belt off. I think it's the balancer. How big of a job is that one? I swear it's gotta be the bearing in there.
post #67 of 88 Old 09-29-2013, 07:23 AM
big_o_tom
1978 CJ7
I didnt read through all five pages but have you considered the throw out bearing to be the problem? My jeep made a similar noise for about six months, not constant just random. Now it gotten worse and is definately the t.o. bearing.
big_o_tom is offline
post #68 of 88 Old 09-30-2013, 06:58 AM Thread Starter
rollmodel1
1979 CJ5
I havent checked anything on the throwout bearing. My harmonic balancer has a slight wobble to it though and thats what makes me think that is what it could be. I went ahead and ordered one but I'm not sure if the harmonic balancer is something i should tackle myself or take it to a shop. Any opinions?
Whats the throwout bearing sound like when its going bad?
post #69 of 88 Old 09-30-2013, 07:27 AM
MoneypitCJ5
1977 CJ5
Usually a throw out bearing noise will change when you engage/disengage the clutch. It will make noise with the clutch released but not engaged unless it's really bad.
A balancer replacement isn't too difficult, but you may have to remove the radiator to do it. Just remove the pulley, take the big center bolt out, use a balancer puller to remove. The balancer has a slot in it that goes over the woodruff key in the crank....line those up and install the new one with a balancer installer or a big hammer and a scrap piece of wood. The rest of the install is the reverse of removal. Tighten the crap out of the big bolt- it's usually torqued to around 100 ft-lb
As always though, if you aren't totally comfortable doing it, a shop will be happy to help.
post #70 of 88 Old 09-30-2013, 07:37 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Roll,
Swapping the balancer requires a puller/installer tool. Most auto parts stores will have one to rent.
It's a relatively easy job once you have the tool.
Matt
Matt1981CJ7 is online now
post #71 of 88 Old 09-30-2013, 10:03 AM Thread Starter
rollmodel1
1979 CJ5
If thats the case then its def not the throwout bearing because it has nothing to do with my clutch. As far as the balancer is concerned, i think i might just take it to a shop once the balancer comes in. I ordered it on Saturday and it may be at my Carquest today. My carquest doesnt rent the puller, but you can buy one but I'm not sure of the price. I think on this piece, I'll just have a shop install it. I'm going to get my Jeep hot before I take it over there and make sure the guys at the shop hear what I am talking about when it comes to the squeal. I made sure this weekend that it wasnt a vacuum leak when I put my new valve cover gasket on. I played with every line on the Jeep and there was no leaks that I could find.
post #72 of 88 Old 09-30-2013, 12:42 PM
Dngrs1
1979 CJ7
The harmonic balancer on my 258 in the CJ had the outer ring slip as did the one on the 401 in my J-10. Neither one of them made noise. I discovered it when trying to find TDC. I have seen them, on other vehicles, separate and just kind of flop around. The sound it makes when it is that bad is like little bells ringing.
The source of the noise you have, I'm thinking, could be the oil slinger. It is mounted on the crankshaft, behind the front seal. You will have to remove the timing cover to access/ replace it.
You should be able to check the balancer by putting the engine at TDC and see if the timing mark lines up @ 0*
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #73 of 88 Old 09-30-2013, 07:18 PM Thread Starter
rollmodel1
1979 CJ5
Do you all think any kind of oil or engine additive could cure this problem?
post #74 of 88 Old 09-30-2013, 07:24 PM
Matt1981CJ7
1981 CJ7
Not likely, but it's worth a shot.
My recommendation is to take it to a experienced mechanic who is capable of diagnosing the problem quickly and accurately. Then decide if it's a repair you want to tackle, or not.
Matt
post #75 of 88 Old 10-01-2013, 06:37 AM Thread Starter
rollmodel1
1979 CJ5
Matt
Matt that is probably the best plan. I need to find some time to be able to do that and maybe Friday would be the best day for that. At this point in time it seems like I have a list of things that it could be, but which one is my question? If the sound wasnt so annoying I'd say forget it! haha
