-   -   CJ Tea Kettle Squeal at idle and low RPMs (http://www.jeepforum.com/forum/f8/cj-tea-kettle-squeal-idle-low-rpms-1598489/)
rollmodel1 09-18-2013 06:25 AM
I know this has been posted before but I want to try my luck on the CJ forum. My 79 CJ with the 258 has a "tea kettle" sounding squeal when the motor is warmed up at idle and at low RPMs. I thought it was the belt, so I replaced it. The problem continued and it sounded like it was coming from around the alternator so I replaced it as well. I took it for a test drive last night to get her warmed up and sure enough I idled into the gas station and the squeal returned but not as loud. It only does it every minute or so at idle and then goes back to purring like a kitten. A minute or two later, the squeal kicks in again. Its nothing major other than a major annoyance. Do I not have the belt tight enough or is it the idler pully? Any help would be really appreciated! Thanks!:2thumbsup:
capt205 09-18-2013 06:52 AM
Had something that could be described the same way...turned out to be low oil pressure related.
The front #1 rocker arm was not getting enough oil, causing the pushrod to basically drill through the rocker arm. While this was happening, it would intermittently squeal like a kettle. Happened to 3 sets on the #1 only. Once I put in the new Melling 4.0 HV pump...no more low pressure, no more tea kettle like squeal, no more pushrod or rocker damage.
Matt1981CJ7 09-18-2013 07:04 AM
In my experience, a slightly loose belt will usually squeal when you rev a cold engine, not at idle with a warm engine.
You might try using a 3' chunk of garden hose as a stethoscope to isolate the noise.
Matt
bradleybrb 09-18-2013 07:43 AM
Not sure what the "squeal" sounds like, but I had a small vacuum leak one time that would sort of make a tea kettle sound.
rollmodel1 09-18-2013 08:28 AM
CAPT, I want to change the oil pump anyways and as a matter of fact that is one of the next things on my list. I've only had this JEEP since August and I am slowing doing things my way as I have time. I appreciate the feedback though. Its so weird though because she will sit and purr like she is supposed to and then a slight squeal that might last 20 seconds and then right back to the purr. A few minutes later, the squeal returns and 10-20 seconds goes by and she is back to normal.
rollmodel1 09-18-2013 08:29 AM
Bradley did you vacuume leak squeal start and stop or was it continuous?
rollmodel1 09-18-2013 08:31 AM
Matt
Good call Matt, and I will try that to see if I can pin point the problem. I'm no mechanic, I'm a JEEPER and I'm learning.
Hawk4097 09-18-2013 08:34 AM
Mine did that a while back and it turned out my intake/exhaust manifold bolts were loose.
rollmodel1 09-18-2013 09:05 AM
[QUOTE=Hawk4097;16108985]Mine did that a while back and it turned out my intake/exhaust manifold bolts were loose.[/QUOTE
Where the manifold connects to the block?
BubbaK 09-18-2013 10:12 AM
I had a similar problem years ago. It was my carberator not tightened down all the way at the base. But the squeal would get louder with rpm.
'83 CJ-7_258 I-6_T-4_D300_AMC20/D30_Bone Stock
Hawk4097 09-18-2013 11:01 AM
Yes the bolts that bolt it to the head
rollmodel1 09-18-2013 12:10 PM
I'll give that a try and see what happens. Its just strange because in my opinion it does seem to come from the passenger side towards the front of the motor.
Hawk4097 09-18-2013 01:13 PM
I thought the same thing even replaced the belts and the water pump...then i stumbled on the bolts being backed out.
rollmodel1 09-18-2013 02:26 PM
I'll give that a whirl this week and see what happens. I hope you're right. That means I dont have to spend any more money just some ratchet work haha!
capt205 09-18-2013 03:58 PM
Where my noise was coming from...I thought it was the alternator.
The time now is 04:33 PM.
