CJ tach wiring - JeepForum.com
post #1 of 5 Old 01-07-2012, 11:47 AM Thread Starter
dd4bama
CJ tach wiring
I bought a used tach and am in the process of cleaning it up for installation. The back two wires were unattached, and I don't know which wire goes where. Can someone identify these and tell me which goes on which side (red and red with white stripe), or if it even matters? Thanks.
dd4bama is offline
post #2 of 5 Old 01-07-2012, 12:18 PM
JeepHammer
Running On Empty...
1973 CJ5
Sure,
Look at your ignition switch.
There will be a connector just a little way from the switch where the tach goes in the dash, even if there isn't a factory tach.
Hooked up one way, it will work, the other, it won't.
Look at the wires in that connector to tell where the 'Strip' wire goes,
And look at the wire out to the ignition.
Since the wires are removed, you will just have to test it and see which way it works.
Is there any markings at the terminal connection points?
Like an 'S' for 'Switch' and an 'I' for ignition out to the engine bay?
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #3 of 5 Old 01-07-2012, 02:23 PM Thread Starter
dd4bama
I looked, but there is nothing on the tach itself. I'm not sure I'm advanced enough to really identify the connector you are referring to. Is it a factory snap-type connector?
dd4bama is offline
post #4 of 5 Old 01-07-2012, 04:51 PM
gpower77
It will be on the right side of the steering column, close to the firewall, and will be a heavy gauge red wire that is plugged together with a black connector. Unplug that connector, and have the tach in series, so red wire coming from the ignition switch, to tach, then tach to the firewall side red wire connector. May have to try swapping the wires on the tach around if you loose voltage to the distributer.
Garry
gpower77 is offline
post #5 of 5 Old 01-07-2012, 05:07 PM
88gmc1
88gmc1 is offline
tach wiring help myzoo Jeep CJ Forum 6 03-22-2011 09:10 AM
Tach Wiring mjeckell Jeep CJ Forum 12 03-11-2010 11:00 AM
Tach wiring help adam85cj7 Jeep CJ Forum 13 02-09-2007 10:17 PM
wiring a tach durdenclub Jeep CJ Forum 5 08-11-2004 06:32 AM
tach wiring 93vert Jeep CJ Forum 1 02-19-2002 11:28 PM
