CJ Starter Problems - JeepForum.com
post #1 of 10 Old 05-10-2013, 10:52 AM Thread Starter
Rob83CJ
1983 CJ7
CJ Starter Problems
I have an 83 CJ with a 258 for about 2 years. In that time I have put in 4 starters. What happens is I put in a new one, and it works fine for about 10 starts, then I start hearing a bad noise everytime I start. At first it sounds like the starter is struggling to turn the flywheel then a big BANG, then struggling to turn the flywheel then BANG again. It will start like this far about 2-3 times then I just hear the starter turning freely without engaging the flywheel. I've had a couple of people look at the flywheel teeth and all say they look fine. I would definitely appreciate any ideas you guys might have...thanks in advance.
Rob83CJ is offline
post #2 of 10 Old 05-10-2013, 11:06 AM
PROJECT 23
How's the alignment of the starter and the fly wheel? Are the teeth positioned properly as I know some need spacers installed to get the correct alignment.
PROJECT 23 is offline
post #3 of 10 Old 05-10-2013, 11:09 AM
Davis77Cj
1977 CJ7
ditto ^^^
had a similar problem on my boat, it bolted up fine and looked straight but when engaged the starter was binding from being at an angle.
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #4 of 10 Old 05-10-2013, 11:10 AM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
I had seen this issue before. Found the thread for you. This should help a lot!
http://www.jeepforum.com/forum/f8/86...grind-1513007/
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #5 of 10 Old 05-10-2013, 04:04 PM
PROJECT 23
Please keep us posted on this issue.....
post #6 of 10 Old 05-15-2013, 06:19 PM Thread Starter
Rob83CJ
1983 CJ7
Thank you guys!!! I'll keep you updated. Have a guy working on it now and I'll pass this along. Much appreciated!!
Rob83CJ is offline
post #7 of 10 Old 05-16-2013, 08:44 AM
PROJECT 23
That guy working on it better be you as working on a starter is easy. I changed out my starter in 10 minutes and that was with downing a beer.
Just messing with you......
post #8 of 10 Old 05-17-2013, 02:37 PM
PROJECT 23
That guys arms must be sore from working on the starter all this time..... Spill the beans with the status......
post #9 of 10 Old 05-18-2013, 02:33 PM
CJ7KAHUNA
I had this issue and my mechanic friend ended up fabbing some shims and shimming the starter. It worked. I am currently having my motor changed out and am changing bell housings while the motor/trans is out. Hopefully this will fix my issue.
This starter issue is the biggest PIA I have dealt with. Its also very common. If someone has posted, or does post a definitive repair thread on this issue I vote for having it stickied or having it added to the CJ Stickies thread.
CJ7KAHUNA is offline
post #10 of 10 Old 05-19-2013, 05:50 AM
86cj74.2L
86cj74.2L's Avatar
All the starter noise for Grammys 86 CJ was I didn't have the dowels pressed into the block. They are what locates the starter.
You don't shim a ford starter. If shimming it fixes it the dowels are most likely not in the block in the lower two corners.
PS. That is what fixed Matt's starter noise.
86cj74.2L is offline
bang , banging , cj , starter
