Quantcast CJ Snorkel? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ Snorkel?
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 07-22-2005, 12:32 PM   #1
Mud4U
CJ Snorkel?
Where can I get a CJ Snorkel? Everywhere I look they have them for the YJ, TJ, and XJ.
[COLOR=darkgreen]85 CJ7- 258 I6, Borg-Warner T176, Dana 300, MC 2100 1.14 300 CFM, Super Swamper 34's, SOA Scout Dana 44's Front And Rear, Rear Locked With Mini Spool, 2" Lift Double Wrap Springs, 3" Body Lift. Yj-Rollbar, Half Doors, Fiberglass Tub And Fender Flares.
93 Cherokee 4x4- 4.0 H.O, Auto Trans, Grizzly Rims
[/COLOR]
Mud4U is offline   Reply With Quote
Old 07-22-2005, 12:50 PM   #2
dawgates
1980 CJ7
Please! Don't screw up a perfectly good CJ with a snorkel. I and many others have forged creeks, stream and rivers in the midwest and never needed a snorkel.
Leave it the guys with YJ and TJ to screw up a Jeep hood!
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline   Reply With Quote
Old 07-22-2005, 12:51 PM   #3
waywardfool
1973 CJ5
build yer own.
google for 'homemade snorkel', 'pvc snorkel', etc and get some ideas
i made one from 3" exhaust tubing, have posted pics a few months ago here a jeepforum....try the search here
edit: found my post: http://www.jeepforum.com/forum/f8/last-nights-work-my-cj-snorkel-plus-164384/?highlight=snorkel
my Cj is all done and on the road now, I'll try and get a nother pic outside
waywardfool is offline   Reply With Quote
Old 07-22-2005, 12:52 PM   #4
LT1CJ7
1983 CJ7
Why, Ya going swimming
Whats the point
Are you going to make it a swamp buggy
LT1CJ7 is offline   Reply With Quote
Old 07-22-2005, 01:16 PM   #5
waywardfool
1973 CJ5
I'll scare up some pics that'll show you why. Better than a chunked motor. Yes, we will swim the river on one of our trails, and soupy mud that'll cover a 35" tire.
Also have found that on dry dusty trails, air filter stays cleaner, as you are "breathing" cleaner air up high, without the stirred up dust.
edit: BTW, I think the PVC snorkels look pretty cheesy, like something from Kmart or off of an H2. But it allows you to be pretty creative for not a lot of money, tools, or fabrication time.
Old 07-22-2005, 01:44 PM   #6
LT1CJ7
1983 CJ7
An ugly A$$ snorkel is an airflow restrictor on the trails.
It will also cause a rich mixture.
Your snorkel is only as good as your other engine components.
Your distributor, coil, ecm, plugs/wires all have to be water proof.
Just about everything electrical.
You better make sure that your snikeler has zero leaks
Old 07-22-2005, 03:22 PM   #7
TheJunkMan2005
What I've read a lot about is people just putting the air intake into the drivers compartment, that way there is no way that mud and such will get sucked into it, and you don't have to look at a snorkel while driving.
A guy locally has a Toyota w/about 4" of lift, and has a snorkel.. That's gotta be the stupidest, ugliest, most useless thing I've seen around here. Up in my corner of CT, we have no trails for even mild wheeling. Where they heck does he plan on submersing it to the top of the windshield??
TheJunkMan2005
1988 Wrangler 89000 miles, no rust, no rot, all nice and pretty.. Runs down the highway really nice too.. This is great fun.
TheJunkMan2005 is offline   Reply With Quote
Old 07-23-2005, 01:51 PM   #8
jeepdaddy2000
1971 CJ5
While I agree that a snorkle has limited uses, if someone want's to install one, good for them. How about some positive feedback for this guy. Much better than pissing him off and leaving a bad impression of the forum.
jeepdaddy2000 is offline   Reply With Quote
Old 07-23-2005, 02:08 PM   #9
waywardfool
1973 CJ5
thanks, daddy....i was begining to look for eye patches, parrots, and peg legs
Old 07-23-2005, 02:28 PM   #10
speedracer2536
they are not made for the cj or any carberauted jeep engines beacuse when idleing you heed greater air flow than the snorkel can take in but with fuel injection you can have one beacuse of the map sensor and it adjust to the air flow
speedracer2536 is offline   Reply With Quote
Old 07-23-2005, 02:30 PM   #11
LT1CJ7
1983 CJ7
WWWAAAAAAAAAAAAAAAAAAAAAA
Stop whining
I would expect a want for a snorkel from a tj owner.
A snorkel is completely useless except for using it for a submarine jeep.
It looks like crap.
It restricts your needed airflow.
It's going to suck up every bit of dirt/dust.
For the geniuses with the home built non filtered snorkel
it's going to get something kicked up into the opening and
drop down into the combustion chamber. KAPOOWIE
Sure, if you just have to have one get one. It's your jeep
But don't cry if you get flamed for it.
Whiner
Old 07-23-2005, 04:04 PM   #12
CGrugger
Previously johnnyboy_1013
CGrugger's Avatar
ok, then i Have a question. While i am driving my CJ-7 through mud, or even hitting a puddle of water on the street. For instance I was pulling into a gas station in the rain and i hit a puddle that was about 3-4 inches deep, water flew up everywhere. My engine died down and i had to run it for about 2 minutes before i got enough power back to drive. This happens at mudholes and on the street. The little For instance i left was the worst it has happened, I noticed water in the intake opening while i was letting it idle.
i have the stock intake housing, but i do not have the little tube that runs from the intake housing to the radiator area. If i got another one of those tubes would that solve the problem.
I dont want a snorkle because I dont do river crossings and stuff. I just want to solve my water/intake problem.
85 CJ-7: 2 inch body lift, Weber Carb, 33 inch tires
07 WK Limited: 4.7, QT-II
CGrugger is offline   Reply With Quote
Old 07-23-2005, 04:14 PM   #13
gigihurt
Sounds to me like you need to seal your ignition as much as you need to seal your carb area.
83 cj7 all stock except lift and tires and all the drive train.
gigihurt is offline   Reply With Quote
Old 07-23-2005, 04:23 PM   #14
CGrugger
CGrugger's Avatar
How should i go about doing both. I have heard from a friend that has a land rover that the shop he went to used silicon sealant, is that good. What should i do
help me
Old 07-23-2005, 09:07 PM   #15
Mud4U
I would not have started this thread if I knew it would throw some people into a$$ mode.
I never stated whether it was for my jeep or a friends. Also I never asked if I or anyone else should get one. I just asked if anyone knew where to get one or if they made them.
I have learned a hell of a lot here and hope to keep doing so. Childish flaming BS or not.
[/COLOR]
Glock Forum
