CJ Shackle Bushings - JeepForum.com
post #1 of 3 Old 02-17-2002, 09:17 AM Thread Starter
HighCountry
Talking CJ Shackle Bushings
I just HAVE to do something to my "new" CJ to personalize it! What are some suggestions for spring shackle bushings? I know of stock rubber and "polyurethane", has anyone used the type that have "grease zerks" on them for lubrication?
Also, what lubricant goes in the T-176 transmisson and the Dana 300 transfer case? I will get a factory shop manual, but I want to change these NOW!!!
Thanks again, Bruce
You folks will be seeing a lot of me, now that I have finally got a REAL Jeep again!! I want to thank you in advance for all suggestions and help!
HighCountry is offline
post #2 of 3 Old 02-17-2002, 02:44 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
I have 0" lift heavy-duty, greasable shackles on mu CJ, a VERY worthwhile investment, since the stock ones are weak. I do think the ride is a bit better with the grease. I think they are made by 4WD Hardware, but the Currie ones are nice too.
Not sure about the tranny juice, it's likely gear oil, which is what the Dana 300 uses. I forget and I'm too lazy to go the basement, but it's the usual 90W - blah blah blah, very common, as it is also used in the diffs.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 3 Old 02-17-2002, 06:34 PM Thread Starter
HighCountry
Post
Thank you sir! I will order a set of "greasers" tomorrow.
Bruce
'86 CJ-7
'95 Cherokee (201,000 miles)
Poly Spring and Shackle Bushings sanddrag Jeep CJ Forum 7 12-16-2009 09:08 AM
shackle bushings poly or OEM? keithf Jeep CJ Forum 8 01-10-2009 08:21 AM
Spring/Shackle Bushings Blue83CJ7 Jeep CJ Forum 4 12-04-2006 02:47 PM
Shackle bushings, replace? Blthomas Jeep CJ Forum 1 10-18-2005 09:43 AM
replacing shackle bushings daoliv Jeep CJ Forum 5 05-26-2004 10:49 AM
