CJ ROLL CALL!!!!! Lets see them all! - Page 493 - JeepForum.com
 325Likes
post #7381 of 8679 Old 04-21-2014, 09:12 AM
CrazyHorse1979
CrazyHorse1979's Avatar
1979 CJ5
Another 2.
CrazyHorse1979 is offline
post #7382 of 8679 Old 04-21-2014, 09:55 AM
SKT
Originally Posted by CrazyHorse1979 View Post
79 CJ-5 304, 3 speed 1,960 miles.
Another 2.
Wow, that is a clean/nice looking '5!
Assuming the mileage is since the restoration/rebuild?
Amazingly clean garage too!
SKT is offline
post #7383 of 8679 Old 04-21-2014, 03:01 PM
Renegade82
1982 CJ7
Nice looking five!
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #7384 of 8679 Old 04-21-2014, 03:47 PM
CrazyHorse1979
1979 CJ5
Thank you for the complements. I just completed the shop around last October, the shop is something I have wanted since I was a mechanic back in the 70's. I love the 76-79 CJ-5's because I know them intimately since special ordering my 1st one from Toledo back in 77. This new 79 that I posted photos of has everything NEW on it. OEM Steel Tub (not an import), all body panels and braces, brake lines, complete fuel system including all the lines and frame retainers, tank, skid plate, emission components, ETC. (except Edelbrock intake, 4 barrel & air cleaner, valve covers). As a result of loosing the warm air updraft (Factory Air Cleaner) it's a little cold blooded but I'm going to tighten the choke a bit, adjust the carb mixture screws to peak rpm and set the timing as far as I can get away with. When I saw this on line, a twin to my 77 Loden Green, except 304 in place of 258, for sale and hit the owner with a price it was a done deal. I looked at over 100 dig photos, video and had a cert mechanic check it over since I am in SC and the Jeep was in Colorado. In the photos and even up on my rack in the shop it appears as though it rolled has just rolled off the assembly line 1900 miles ago, SERIOUSLY. The frame even appears new on the inside and outside. I believe the motor was completely gone through due to the cleanliness of the block, new freeze plugs, etc. Who ever put the rear main 2 piece seal in failed proper installation (leaking) so we fixed that last week, made the cooling system a little bigger by adding an over flow bottle and closing the system at radiator. One thing I did use for the 1st time on seals and gaskets because of some of my research, is use Loctite 518 anabolic sealer. Especially where the 2 piece seal 1/2's meet and in the corners of the main bearing as procedures call for, but I also used the primer that was recommended by Loctite (#7649 Sealer/Primer) for this sealer on all the sealing surfaces, block, pan, and on both sides of the cork and rubber pan gaskets. I've driven this a few time since the seal was done and it is bone dry. Gasket stayed and no pooching. I'l be putting a few custom touches on it because I'm real particular, but only to improve what is there already.
post #7385 of 8679 Old 04-21-2014, 03:52 PM
CrazyHorse1979
1979 CJ5
One thing I forgot. . . I love my Mohawk Lift! Especially with a real bad right elbow, shoulder (very limited range of motion), and just had my right hip replaced.
post #7386 of 8679 Old 04-21-2014, 05:25 PM
JAngeli
Real nice 5er.
You have more pics of the shop?
JAngeli is offline
post #7387 of 8679 Old 04-21-2014, 05:49 PM
CJustin7
Another 2.
Beautiful
Patience WJ EXPO Build
CJustin7 is offline
post #7388 of 8679 Old 04-22-2014, 11:29 AM
jason400
View from my office window. Keeps me motivated.
jason400 is offline
post #7389 of 8679 Old 04-22-2014, 02:34 PM
orange150
1982 CJ8
New here, and relatively new to CJs, so I'm doing a lot of searching and will have a few noob questions on the horizon.
'82 CJ-8 258/T5/D300. AMC Model 20/D30.
Has had a decent restoration, the last to be figured out is the dash and of course a few odds and ends things.
'82 CJ-8
258/AX15/D300
OME YJ 2.5"/31s
D30/D44/3.73s/Truetracs
orange150 is offline
post #7390 of 8679 Old 04-22-2014, 08:30 PM
berettajeep
1947 CJ2A
In Wyoming. Just drove it from Ohio to Oregon.
You can read about here in my build.
http://www.jeepforum.com/forum/f22/m...build-1275816/
Or go straight to when I left. http://www.jeepforum.com/forum/f22/m...l#post22351657
'74 Cherokee 401
berettajeep is offline
post #7391 of 8679 Old 04-22-2014, 09:55 PM
only in a jeep cj
Great looking 8! Love the lift/tire/rim combo! Very clean. BUT why the black hinges? Those I'm not liking.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #7392 of 8679 Old 04-23-2014, 02:35 AM
CrazyHorse1979
1979 CJ5
Nice looking Blue!
post #7393 of 8679 Old 04-23-2014, 03:16 AM
gazzo
Another 2.
Danielsan will be frothing on this one
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline
post #7394 of 8679 Old 04-23-2014, 03:23 AM
CrazyHorse1979
1979 CJ5
Originally Posted by JAngeli View Post
Real nice 5er.
Tons:
It's a Morton 30'x45" with 14' walls. It's got an A/C 21 SEER split system heat pump.
post #7395 of 8679 Old 04-23-2014, 04:29 AM
CrazyHorse1979
1979 CJ5
Real nice 5er.
Some more shop photos during build. The left corner of the porch is just about where the big Magnolia was.
bh10
Roll Cages - Lets See Pictures imaldini Jeep CJ Forum 50 06-14-2016 04:43 PM
Net Call Net Call Net Call!!! gunnhr Jeep CJ Forum 9 03-30-2012 07:07 AM
What do you call it? PeteTx Jeep CJ Forum 11 07-23-2010 02:43 PM
What is the strongest clear coat you can roll on the roll bar over fresh paint? HHICJ7 Jeep CJ Forum 2 12-10-2009 04:27 PM
Call To Vote!! evilpsych2 Jeep CJ Forum 2 11-07-2002 09:54 AM
