CJ ROLL CALL!!!!! Lets see them all! - Page 429 - JeepForum.com
 181Likes
post #6421 of 8580 Old 02-02-2013, 11:00 PM
WSS
WSS's Avatar
1972 CJ5
Originally Posted by dawnatron View Post
Howdy and thank you for this great resource. My Dear Husband and I are currently grounding all of the electrical components on my CJ5 per the great advice here from JeepHammer. I've loved this Jeep most of my life. My dad bought it in 83 from the first owner and I just bought it from him a few weeks ago. It had 70,000 miles on it when Dad bought it 30 years ago. He put 5,000 ranch miles on it. It's been a challenge doing what I call the Ranch-to-Street conversion. Little things, like the key being in it for 30 years, the release lever is a pain; turn signals and brake light switches had to be replaced (who you going to signal to on a deer lease?).
But we had been having a lot of problems with the electrical system. We have diagnosed it to the negative side, and did see improvements on the meter simply from removing the Rhino liner from the firewall to the terminal ring on the ground wire. Yeah, Dad painted the whole thing, inside and out, in Rhino/Dura type liner. He obviously wasn't thinking about the electrical connections when he painted the firewall with it. We've ground all of that down to bare metal and already seen an improvement on the negative side load.
By tomorrow we will have added 3 more dedicated grounds and I hope I'm right that this will fix our problems. Other than this grounding issue the thing is in remarkably great shape. Did I mention it's a 1977 and only has 75,000 miles on it?
About 3 years ago Dad stripped it down to the bare frame and completely restored it. He replaced every nut, bolt and washer with stainless. It has lots of custom mods he fabricated in his own shop for hunting including an aluminum hoist that fits into the front receiver for field dressing deer. There is a high seat that mounts to a custom rear rack for bow hunting, which had a corn feeder that was mounted to the underneath of that. We left the feeder on his ranch and have the bow stand and rear rack stored, it won't fit in the garage with everything that goes on it. We also have everything for a winch except for the winch itself, all the wiring is there but disconnected and Dad gave me a whole box full of parts including the brass "plug" as he calls it for the winch, extra belts, a few dozen sets of stainless nuts, bolts, washers, lock washers, and so on. I've been happy that every time we need a nut, bolt, or washer all I have to do is dig through Dad's box and there it is. Also that my Dad is the type of guy who will use a 4x4 when a dowel rod would have been sturdy enough ... you should see the hardware under the seats where he moved them back and permanently mounted them as far as they will go (he's 6'4" and it's a CJ5 ... ) ... can't wait to take it out and try to break something!
Thanks again for all the great resources here.
Anyway it's a bit of work at the moment, but I'm happy to join the Jeep community. I appreciate all the waves out there on the roads! Just pray that we get back out there to wave back this weekend!
Cool CJ! Looks like it will be fun. Electrical can be hair pulling on these guys. I recently dropped my tank and re-wired the entire rear and found it would pop a 30 amp fuse when the brakes were pushed, when the right turn signal was turned on (it was the left that was trouble before?) and on the second click of the hazards. Had to be at the back on the stuff I "fixed" right? 6hrs later, I tracked it to a new short in the turn signal mechanism. Fun!
Enjoy the treasure!
WSS
WSS is online now
post #6422 of 8580 Old 02-03-2013, 10:54 AM
dawnatron
1977 CJ5
Thanks WSS! Well the Husband wouldn't believe it until I proved it, but the whole problem turned out to be faulty wiring on the windshield wiper motor. Unplugged it from the circuit at the switch and SHAZAM the wire going into the voltage regulator had current through it. This forum and links to a great wiring diagram were life savers so thanks again to all of you! I did take the .opportunity this morning to give my dad a little grief about all the rhino liner in between the metal components that hook to the body and the body itself. The dedicated grounds did not ultimately fix the alternator charging problem BUT it did reduce the resistance on the negative side of the system from .4 to ZERO and I'm very happy about the upgrade. Some pics below.
electrical3.jpg   electrical4.jpg   electrical1.jpg   electrical2.jpg   electrical6.jpg
dawnatron is offline
post #6423 of 8580 Old 02-03-2013, 10:57 AM
dawnatron
1977 CJ5
Oh if anyone is planning to undertake work putting a ground from the starter to the block, be careful with the line that goes to the oil pressure gauge! We broke and had to repair that in the process. I am going to find and install something other than that cheapy brittle plastic line.
post #6424 of 8580 Old 02-04-2013, 12:29 PM
ZombieCrush1
1981 CJ5
New to the forum, long time jeeper
I just got this beast back on the road.
ZombieCrush1 is offline
post #6425 of 8580 Old 02-04-2013, 12:58 PM
8pitcher
8pitcher's Avatar
Awesome.
sent from the bottom of an empty money pit
8pitcher is offline
post #6426 of 8580 Old 02-04-2013, 03:31 PM
robrich
robrich is offline
post #6427 of 8580 Old 02-04-2013, 03:41 PM
robrich
robrich is offline
post #6428 of 8580 Old 02-04-2013, 06:30 PM
knotslippin
1980 CJ5
Newbie here
Well Finally picked up my first Jeep. Always been a Toyota guy. Joined here to pick some brains and learn about Jeeps.
I traded an Airboat for this Jeep. It's a 1980 CJ5 V8 304
Needs some rust repair and floor boards replaced. But it is only going to be for the mud...
I am in the Loxahatchee area, so if anyone is hitting Corbett let me know. I would like to check it out with someone thats been there. Looking forward to learning..here she is
Thanks in advance for any info
Guy
knotslippin is offline
post #6429 of 8580 Old 02-04-2013, 08:07 PM
74Maverick
Well The CJ5 is my new v8 baby, the garnet cj7 is my currently sidelined 4 banger and the ugly one flexin is my long lost nasty old 79 CJ7
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
post #6430 of 8580 Old 02-06-2013, 06:01 PM
rylstr95
1968 CJ5
My 68 cj5
rylstr95 is offline
post #6431 of 8580 Old 02-06-2013, 08:30 PM
ochaunceyj
New guy here...looking forward to learning a lot from this forum. Here's my 1981 CJ7
ochaunceyj is offline
post #6432 of 8580 Old 02-06-2013, 08:34 PM
19in1979
1979 CJ7
Originally Posted by rylstr95 View Post
My 68 cj5
Love it!
BTW, I see the install truck parked there next to you. Are you in the security/fire/CCTV industry? If so, you probably know of ADI. I was with them for 25 years and before I became medically retired, I was the Sales Manager for the Rocky Mountain Region which oddly enough meant managing everything from Minneapolis on the east, to Boise on the west. So glad to be gone now that Honeywell owns them.
Best regards,
Wayne
Living the dream at 8,500ft. elevation in beautiful Coal Creek Canyon, Colorado.
19in1979 is offline
post #6433 of 8580 Old 02-06-2013, 08:38 PM
cbel
Hey im also new here is my baby getting ready to do a SOA
cbel is offline
post #6434 of 8580 Old 02-07-2013, 07:19 AM
firefghtr86
1972 CJ5
I am new to this forum.. as well as new to jeeping.. but I am in love I must say! My husband got me this beautiful old "heep" as we call it.. and we are in the process of restoring/rebuilding it "one piece at a time" (Johnny Cash) I am learning that patience pays off. We were fortunate enough to have full doors/hard top and half soft doors. The only modifications that I am aware of is a added radio and speakers, not the correct wheels, winch on front and missing rear tire rack. I would like to make it back as original as possible... The 304 is a nice motor, I have heard reviews both ways.. and as much as a 350 sounds great in it.. I am going to stay stock.. with this one anyway. They dont make things like they used to. If anyone has info on this year/make please let me know. I am told it is the super jeep (according to jeep documents) I would like to find orignal stlye wheels, new stickers, and possibly a full soft top.
firefghtr86 is offline
post #6435 of 8580 Old 02-07-2013, 08:57 AM
8pitcher
8pitcher's Avatar
Look on the firewall right around the brake master cylinder and there will be an identification number. Then google jeep identification and find it.
8pitcher is offline
trudz516
Roll Cages - Lets See Pictures imaldini Jeep CJ Forum 50 06-14-2016 04:43 PM
Net Call Net Call Net Call!!! gunnhr Jeep CJ Forum 9 03-30-2012 07:07 AM
What do you call it? PeteTx Jeep CJ Forum 11 07-23-2010 02:43 PM
What is the strongest clear coat you can roll on the roll bar over fresh paint? HHICJ7 Jeep CJ Forum 2 12-10-2009 04:27 PM
Call To Vote!! evilpsych2 Jeep CJ Forum 2 11-07-2002 09:54 AM
