CJ Radio Fuse Wiring - JeepForum.com
post #1 of 12 Old 04-06-2012, 03:03 PM Thread Starter
jkwheels
1978 CJ5
Have 78 CJ5. Radio works but memory on radio does not. Second power wire is not hooked up. I know it needs to go to a fuse that is live when ignition is off but not sure where to connect it. The main power wire is female and hooks to fuse box where is says radio. The second power wire is flat male post. Not sure how or wear to wire it up. Spent a lot of time getting this old fuse box and all electrical working so I want to do it right. Help. Thanks
jkwheels is offline
post #2 of 12 Old 04-06-2012, 03:38 PM
CJ7Sasquatch
1979 CJ7
Cut the end, splice in a line going to the battery pos side, put a inline 10 fuse and call it done. Remember the old radio didn't need it so I don't believe there is a constant power line except maybe If you have the clock
ECV 1864
CJ7Sasquatch is offline
post #3 of 12 Old 04-07-2012, 08:44 AM
John Strenk
John Strenk's Avatar
1976 CJ5
If he doesn't have a clock, the connection is still in the fusebox so I would connect it there.
If you have a clock, Look for a fuse adapter to connect it.
John Strenk is offline
post #4 of 12 Old 04-07-2012, 10:17 AM Thread Starter
jkwheels
1978 CJ5
I have a clock that does not work. I'll see if I can disconnect it, change the male terminal on radio to female and plug it in.
Am I correct that there is no female terminals on the fuse. Box. I can't find anyplace to plug this flat male terminal in.
jkwheels is offline
post #5 of 12 Old 04-10-2012, 09:35 PM Thread Starter
jkwheels
1978 CJ5
John the 78 fuse boxes only has male contacts. What do you mean by fuse adapters?
jkwheels is offline
post #6 of 12 Old 04-11-2012, 03:39 AM
John Strenk
1976 CJ5
I think the 78 still has glass fuses so these are handy
Fuse Tap, Fuse Taps For AGC Round Glass Fuses NAPA Part: NW 785131
Still all male connectors. You will have to change your terminal.
For reference for other types of fuses
http://www1.cooperbussmann.com/6/Bla...cessories.html
post #7 of 12 Old 04-17-2012, 03:51 PM Thread Starter
jkwheels
1978 CJ5
Radio Wiring
Thanks for the help got it fixed yesterday. Found a male terminal above the hazard fuse that was hot when everything was off. made a pigtail turned male wire into female and its done.
jkwheels is offline
post #8 of 12 Old 07-28-2013, 02:39 PM
CJ7ROB
On an '86 the red fuse wire labeled radio in the fuse block is hot only when the key is on correct? Thx
CJ7ROB is offline
post #9 of 12 Old 07-28-2013, 04:17 PM
John Strenk
1976 CJ5
Correct
post #10 of 12 Old 07-29-2013, 09:52 AM
CJ7ROB
Correct
Cool, ok to tap into these radio wires for the cig lighter too? Or better to use another fuse? Thanks
CJ7ROB is offline
post #11 of 12 Old 07-29-2013, 10:09 AM
John Strenk
1976 CJ5
The wiring for the 86 CJ7 cigar lighter should be in the harness already even if you don't have one.
It connects to the backup light fuse.
post #12 of 12 Old 07-29-2013, 10:24 AM
CJ7ROB
Oh ok got it thanks.
CJ7ROB is offline
