CJ power brake upgrade - Page 2 - JeepForum.com
 1Likes
post #16 of 66 Old 04-28-2008, 03:21 AM
GPER
1979 CJ7
I like the YJ brake up grade, mine don't bottom out and are as touchy as any other power brakes. They are a big improvement over the manual brake.
GPER is offline
post #17 of 66 Old 06-21-2009, 08:42 PM
BLEEDNJEEP
jeep cj brake cylinder upgrade
I was watching Trucks! the other day and they were working on an old Int'l Scout. He suggested taking 1 ton brake cylinders from a Dodge and replacing the OEM ones for better stopping power. Has anyone tried putting better cylinders in the rear for the drums?
BLEEDNJEEP is offline
post #18 of 66 Old 10-01-2009, 02:23 PM
twoleos617
only 95 and newer YJ's are dual diaphram right? (95 thru ????)
how can you tell the difference btween a single and dual by looking at it?
twoleos617 is offline
post #19 of 66 Old 10-01-2009, 03:00 PM
CjinPA
CjinPA's Avatar
Only 95 YJ's with the 6 cylinder motor have the dual diaphragm brake booster. You will know a dual diaphragm booster by looking at it. The easy way to tell is the 95 master cylinder will have a plastic resivoir. The single diaphragm brake booster master cylinder has a metal resivoir. If you buy a dual diaphragm brake booster from a 95 YJ make sure to get the master cylinder and brake lines from the master cylinder to the proportioning valve with it because they are metric thread and the lines have a bubble flare. They are not easy to find.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #20 of 66 Old 10-01-2009, 03:34 PM
twoleos617
PERFECT! thx!
post #21 of 66 Old 10-05-2009, 12:34 AM
carnuck
1984 J-Series Truck
I have. Also swapped master cyls with slightly smaller bores for more power on manual brake rigs.
carnuck is offline
post #22 of 66 Old 12-13-2009, 02:01 PM
Mudviper
Is there a significance difference between a brake booster in a 95 YJ with a 4 cyl and a 6 cyl.? When looking up the parts at Auto zone they are both duel diaphragm boosters but with different part numbers. I have lots of salvage yards around me with 4 cyl models but not 6 cyl models
Mudviper is offline
post #23 of 66 Old 12-13-2009, 02:46 PM
crazyeye
1979 CJ7
http://www.bustedjeep.com/projects/yjbrakes.asp
this site hasnt worked for over 2wks now
crazyeye is offline
post #24 of 66 Old 12-13-2009, 05:31 PM
CjinPA
CjinPA's Avatar
The 4 cylinder 95 YJ's have single diaphragm boosters and master cylinders with all metal resivoirs. Basically they are the same as all other 87 to 94 YJ brake systems.
The 6 cylinder 95 YJ's have dual diaphragm brake boosters and the master cylinders have plastic resivoirs. They provinde significantly more braking power. They are basically a TJ brake set up designed to work in a YJ.
84 CJ7 Northstar V8
91 YJ Renegade.
CjinPA is offline
post #25 of 66 Old 12-13-2009, 08:38 PM
Mudviper
I guess what is a bit confusing is that when I pulled up the power booster for a 95 4cyls at Auto Zone it says it is a duel diaphragm not a single diaphragm, but all prior ones for the 4 cyl are single
Mudviper is offline
post #26 of 66 Old 12-13-2009, 11:06 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
They may have done that at the Zone so that they only have to carry one part. Figure the better one works on either, so why stock the weaker one...
Rick
Cutlass327 is offline
post #27 of 66 Old 12-14-2009, 05:54 AM
CjinPA
CjinPA's Avatar
Autozone is not always correct in their parts listings. I found this out the hard way one evening when my alternator died in my F250. With the help of a friend I managed to get the truck to an autozone and they gave me the wrong alternator. The Autozone guy insisted it was the correct part. The mounts on it were correct but the electrical plugs were different. Unfortunately it was not until after they closed that I realised it was the wrong part and I was stuck in Elmira, Ny for the night. When they opened up the next morning I took the factory alternator to the counter with me to compare it to alternators listed for other year F250's. I ended buy an alternator that was listed for a different year ford truck.
The 95 YJ dual diaphragm brake booster will not work with the 87 to 94 YJ and 95 4 cyl YJ master cylinders. You have to use the 95 YJ (6 cyl specific) master cylinder with the dual diaphragm brake booster.
84 CJ7 Northstar V8
91 YJ Renegade.
CjinPA is offline
post #28 of 66 Old 12-14-2009, 06:52 AM
mcurcio1989
1976 CJ7
This is the place to save money. Buy a the cheapest yj mc and booster you can find. I found one for $30. If your worried get the re manufactured mc from autozone or something. That's 50 dollars. Whats the worst thing that can happen the booster might go out? That will make it exactly like you were before the upgrade its gonna be a pain but not unsafe. I doubt that's gonna happen tho. This was designed as a safety feature on the yj and everyone driving a 20 year old yj with an original mc and booster aren't worried that there unsafe because they don't have a brand spanking new booster and mc.
For the record i have unplugged my vac line from the booster and plugged it with a screw and i can still easily stop. Just requires more work from my leg.
See what i am saying??
http://shop.ebay.com/i.html?_nkw=yj+...ster&_osacat=0
Disregard everything i say
I have a dana 30 front axle and amc 20 rear if anyone is looking. Both are 3.54, drums, narrowtrack.
mcurcio1989 is offline
post #29 of 66 Old 12-14-2009, 09:51 AM
jatepper
The dual diaphragm booster from a 95 YJ is even better. Be aware though that with the 258 motor you will have clearance issues with your air cleaner and the dual diaphragm booster.
Couldnt agree more. A lot of people swear by the Vanco brakes and I am sure they offer an excellent system. On my old CJ, I too bought the YJ booster (dual diaphram off a 95) and had no air cleaner clearance issues whatsoever. I did however have an aftermarket 8" diameter air cleaner and it provided me with a couple of inches of clearance between the air cleaner and the booster.
Another benefit of the 95 dual booster is that the fittings are on the driver side when mounted, meaning you do not have to bend/tweak your brake lines to the opposite side if you use an earlier model booster. The stress caused by bending the lines is not such a good idea, but if done carefully should be no big deal.
I remember when I did the upgrade and test drove the jeep around the neighborhood..... the first tap of the brakes almost sent me through the windshield
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #30 of 66 Old 12-14-2009, 04:01 PM
crazyeye
1979 CJ7
i just did the same i had no issues putting the 95 yj set up on mine at all and my 85cj stops even better now. the only thing you have to do is change the brake lines ends to fit the 95 master cylinder cause they are metric advance auto has the fittings.
crazyeye is offline
Power brake upgrade Big Tool Jeep CJ Forum 19 04-02-2013 04:46 PM
CJ power brake upgrade? 84cj Jeep CJ Forum 12 09-04-2009 06:39 AM
CJ Power Brake Upgrade mdub Jeep CJ Forum 9 09-14-2006 03:33 PM
Power Brake Upgrade---look!!!! GADJIT98 Jeep CJ Forum 0 07-29-2004 06:41 PM
How do I do a Power Brake Upgrade on 81 CJ-7 with 350? JasonMonette Jeep CJ Forum 11 06-28-2004 03:56 PM
