CJ no start - JeepForum.com
post #1 of 6 Old 06-22-2013, 02:51 PM Thread Starter
skydog61
1978 CJ5
CJ no start
I have a '78 CJ5 that has a no crank, no start condition. I happened to have a good solenoid laying here so i replaced that just to check and that wasn't the problem. I took the starter and had it tested and it tested good. So now I am figuring it is the ignition switch. Anybody have any experience diagnosing this kind of problem? Just looking for any tips before I dig in.
skydog61 is offline
post #2 of 6 Old 06-22-2013, 06:09 PM
pman
Bagus is the king at electrical diagnosis, so he'll probably chime in, but my redneck self would say you are on the right track. The rod from the key tumbler will insert into the switch on the top side of the steering column (under the dash). It may be that it is out if adjustment or the switch (12.00 part iirc) needs to be replaced. There should be a couple of small bolts that hold it to the column.
Check your fuses and wiring at the bulkhead. May be something loose. Someone who scored higher on their SAT will hopefully reply with a more thorough response.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3 of 6 Old 06-23-2013, 09:43 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Battery terminals and grounds.
Mine was the ground at the block. Wire corroded inside the terminal.
I couldn't find the problem for an hr until the wire fell out of terminal and was hanging there bare.
2Xtreme is offline
post #4 of 6 Old 06-23-2013, 05:26 PM Thread Starter
skydog61
1978 CJ5
Considering the ignition cylinder and ignition switch are original, I think I am just going to replace them both. I am pretty confident the ignition switch is the culprit though. There is a jeep shop just down the road from my work, so i am going to stop in and order both tomorrow at lunch.
skydog61 is offline
post #5 of 6 Old 06-23-2013, 10:41 PM
petey156
1977 CJ5
A quick test would be to jump from the "+" battery terminal to the solenoid start terminal. Make sure it's in neutral first.
If it cranks its in the harness, or ignition switch, if not look at grounds .
petey156 is offline
post #6 of 6 Old 06-24-2013, 04:20 AM
BagusJeep
1981 CJ7
Ah yes, the strategy of replacing stuff without finding out the problem. Sounds like more profits for the local shops.
This could be as simple as the light blue wire having fallen off the solenoid S tab.
Before you get too far you may care to test what you have and find out what is working.
The best tool is a 12V test bulb and long leads. Costs about $5 but is soo easy to use.
Hook one end to the battery negative and go looking for voltage.
Youw ant to find a Bright bulb when you connect to a light blue wire and turn the key to Start. This wire goes to the solenoid S tab to start the engine.
If you do not have voltage here go back to the under column connector. There is a light blue wire coming out of it. Try here for voltage in Start. There is possibly a neutral safety switch somewhere in the harness just before this so it i simportant to check the light blue wire at several locations up to the switch before concluding it is a duff switch.
If you still do not find any check the Red wire going in to the connector, are you finding a Bright bulb here? If so then the switch and/or harness above the connector is not doing its job.
Here is a diagram which may give you afew clues about how the swicth itself operates. It is for a 1984 but very similair.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
