CJ with a new 4 in. lift and 33" - JeepForum.com
post #1 of 18 Old 01-30-2014, 08:17 AM Thread Starter
77CJ7GIRL
1977 CJ7
hey everyone, just recently put a 4in spring lift on my 77' cj7 and 33x12.5 tires. im new to the jeep world. And it seems a little high and almost dangerous when on the road. I have manual everything. and after putting the kit on, the steering column got lose on me again. any suggestions?
77CJ7GIRL is offline
post #2 of 18 Old 01-30-2014, 09:24 AM
bluwtrsurfr
bluwtrsurfr's Avatar
I have 33's on my CJ with a 4 inch lift. In my opinion it's a perfect height. When you installed your lift, did you install a drop pitman arm? With a 4 inch lift your steering geometry is all off. You need to get the linkage close to straight again. I am not sure what you mean about your steering wheel got loose on you. Can you elaborate?
Will
81 Jeep CJ5 4" lift, 33" Mickey Thompson Baja Claw tires.
bluwtrsurfr is offline
post #3 of 18 Old 01-30-2014, 09:38 AM Thread Starter
77CJ7GIRL
1977 CJ7
hi, thanks for the response. So before I put the lift on I replaced the manual steering box. The alignment was perfect no play in the steering wheel at all. Then I bought the kit from rough country. The pitman arm they sent was for 2'1/2 - 4" lift kits. It didnt completely level it down by the tie rod. but what has me wondering, is the steering wheel now has about an inch worth of play. It seems to be from the gear box up to the steering wheel. I normally do all the work myself but I let someone do the kit and im not sure what they messed with.
post #4 of 18 Old 01-30-2014, 09:57 AM
babytank31
1978 CJ5
You have to remember that when you lift any vehicle you change the geometry of your steering components. Just because it was aligned before kit install does not mean that the alignment is still true. Also when ever you lift any vehicle any amount of free play in most components is exaggerated. What you may not have noticed before lift install is very noticeable afterwards. You can check the lower steering shaft coupling, if you have manual steering and now have larger tires you are applying more torque to steering shaft and gear box to turn larger tires which may cause a looses feeling in the wheel that was never noticed before, including flexing of chassis at box location. Ihad to heat, beat and pull like hell to remove my old pitman arm, your mam might have done the same as well. Someone correct me if I am wrong but there is a manual and power pitman arm depending on the box. Make sure that you have the correct one, they should not interchange but who knows.
babytank31 is offline
post #5 of 18 Old 01-30-2014, 10:05 AM Thread Starter
77CJ7GIRL
1977 CJ7
You are correct the power steering pitman arm is different and they are not interchangeable. Do you know it there is a bigger manual steering box for bigger tires and lift? Or what do you have in your jeep? And do you have play?
post #6 of 18 Old 01-30-2014, 10:20 AM
rickscj7boom
Welcome to the sickness, got any pics of the rig??
rickscj7boom is offline
post #7 of 18 Old 01-30-2014, 10:25 AM Thread Starter
77CJ7GIRL
1977 CJ7
post #8 of 18 Old 01-30-2014, 10:31 AM Thread Starter
77CJ7GIRL
1977 CJ7
post #9 of 18 Old 01-30-2014, 10:35 AM
redneckrubicon3
Nice looking CJ, and welcome to the forum. There are more options for steering boxes, both stronger and with a fast ratio.... can't think of any direct fits off the top of my head but will find the list I made when I get home.
WAG MORE, BARK LESS.
Quote: brokeyoujoint "LJ's hold more value than a prostitute who wakes every morning as a virgin."
redneckrubicon3 is offline
post #10 of 18 Old 01-30-2014, 10:39 AM
Waldomas
Check the box for loose bolts. Maybe add a stronger bracket and brace. Check the steering shaft where it couples. Correct camber and castor with an alignment. Is there any body lift and what axles do you have?
Are the shackles original?
Waldomas is offline
post #11 of 18 Old 01-30-2014, 10:39 AM Thread Starter
77CJ7GIRL
1977 CJ7
Thank you and yeah that would be great.
post #12 of 18 Old 01-30-2014, 11:33 AM
Dngrs1
1979 CJ7
Keep in mind that the drop pitman arm is a tad shorter than the stock one. This will result in a slight loss of turning radius and a bit of play in the steering wheel.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #13 of 18 Old 02-03-2014, 01:42 PM Thread Starter
77CJ7GIRL
1977 CJ7
In action
post #14 of 18 Old 02-03-2014, 01:50 PM
IMJEFF
1975 CJ5
Make sure your new steering box didn't get damaged with the pitman arm replacement. Most of them have a lash adjustment. Mine has the same components and the steering is nice. Sometimes a steering stabilizer can give you the feel you want.
Friends will help you move, real friends will help you move the bodies.
75 CJ-5 / 72 K10 LWB / 67 Chevelle 396/4 speed / 74 FXE / 08 Tahoe
IMJEFF is offline
post #15 of 18 Old 02-03-2014, 01:59 PM Thread Starter
77CJ7GIRL
1977 CJ7
I have a steering stabilizer, what do you think about putting a second one on?
