cj motor specs - JeepForum.com
post #1 of 8 Old 08-17-2003, 12:51 PM Thread Starter
travr6
Thumbs down cj motor specs
I have a 258 in a 1976 cj-5 that blew up and i want to put a 258 back in. What years can i use or what other motor could i put in that will bolt in.
travr6 is offline
post #2 of 8 Old 08-17-2003, 01:10 PM
jadams68
jadams68's Avatar
Any 258 from 1972 - 1986 would work.
258's from AMC Eagles will also work.
There are other bolt on engine replacements such as the AMC 304 V8, and 4 cyl AMC 151 and 150.
Stick with the 258 (my .02 advice) you can get them cheap.
Also, define "blew up"
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 8 Old 08-17-2003, 03:07 PM Thread Starter
travr6
Blew up= Threw a Rod. I guess I really only need a block since I am going to rebuild whatever motor I get anyway.
Don't the 258 from teh 80 models have smog crap on them? Does it affect anything if you take that off?
I really want to stick witht the 258 but I figured if there was another motor that bolted right in I would pick it up if it was dirt cheap.
Can't find a 258 any cheaper than $250
travr6 is offline
post #4 of 8 Old 08-17-2003, 04:25 PM
jadams68
jadams68's Avatar
Yeah '83 and newer have the computer controlled emissions equipment, but you don't need any of that stuff. Your vehicle is titled as a 76 and doesn't require a sniffer test for emissions.
You should be able to swap any 258 in as a replacement.
jadams68 is offline
post #5 of 8 Old 08-18-2003, 11:55 AM Thread Starter
travr6
So any 258 will work. Any Idea what year they quit making them? What vehicles can I get one from? Only AMC cars I assume. It will not hurt anything to remove all the smog stuff correct?
travr6 is offline
post #6 of 8 Old 08-18-2003, 12:13 PM
jadams68
jadams68's Avatar
That's my understanding on things. I mean you can definitely find a 258 from a CJ on Ebay from time to time and local yards.
Your current 258 doesn't have smog equipment, so any future engine wouldn't need it either.
jadams68 is offline
post #7 of 8 Old 08-18-2003, 09:35 PM
Jeep Daddy
Jeep Daddy's Avatar
So you fully understand, all you have to do is get any 258, even if it comes with all the smog stuff on it, and rebuild it. When you complete the rebuild you will still need to use your carb., your intake manaifold, distributer, pullies, belts, wires, brackets, air cleaner, hoses, etc. You just wouldn't use the EGR, carb, sol-vac, vacuum hoses, distributer etc. from the newer engine. HTH
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #8 of 8 Old 08-19-2003, 02:47 AM Thread Starter
travr6
Yeah. I meant if I found one and wasn't going to rebuild it could I just take the smog stuff off. If I rebuild one with smog I can do anything I want to it.
Thanx for the help guys.
travr6 is offline
would like to replace 79 CJ7 motor with Ford motor alisa65 Jeep CJ Forum 6 05-05-2009 09:44 AM
building 360 motor need help with specs keith78 Jeep CJ Forum 6 04-05-2009 12:38 PM
SPECS! need some specs MattWtech Jeep CJ Forum 2 03-15-2007 07:10 AM
AMC 318 and 360 specs... vladrulli Jeep CJ Forum 4 05-15-2006 07:03 AM
need blower motor fan specs Ezredcj Jeep CJ Forum 12 12-05-2005 07:53 AM
