CJ of the Month Submissions - JeepForum.com
 15Likes
post #1 of 68 Old 07-01-2011, 04:56 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Post your submission here. Cut/paste the spec list (below) into your post and accompany it with 2 pics. Post the pic below the specs. Failure to follow instructions will get your post deleted.
Submissions will be accepted until somewhere around the 15th of the month at which point the thread will be closed and Voting will take place until the last day of the month.. then the winner will be named.
This is for the November 2014 CJ of the Month..
Specs
Year of CJ
Engine
Transmission
Transfer Case
Front Axle
Rear Axle
Suspension
Tires
Additional Mods
BESRK is offline
post #2 of 68 Old 11-10-2014, 04:38 PM
MC007
1978 CJ5
1978 CJ5 Renegade
AMC 304 V8
Borg Warner T-150 3 Speed Tranny
Dana 20 Transfer Case
Front Axle - Dana Model 30
Rear Axle - AMC 20
Rancho Shocks - 4inch lift
Tires - 33x12.50x15 Mickey Thompson Baja Claw's
Additional mods - Removed front fenders, Painted orange, Boss Wakeboard Tower Speakers accompanied by a Boss head unit, Rhino Lined interior, and a Hula Girl on the dash just because!
MC007 is offline
post #3 of 68 Old 11-16-2014, 11:07 AM
mwroseberry
79' CJ7
4.2L Inline 6
TF999
Dana 300 - Twin sticked
Dana 30
AMC 20
Military wrapped Rugged Ridge factory height - Rugged Ridge .5 lift shakles -Skyjacker shocks
33x12.5x15 Dick Cepek Mud Countrys on Pro Comp Steel wheels
Poison Spyder - Stinger and Crusher 3/16" plate armor, Engo 10k winch with synthetic line, Die Hard Platnium Batt, 20' LED light bar, Rugged Ridge Security Console, CCFabs Tube fenders, HEI ignition, LED tail lights, Custom Rocker armor (3/16" plate steel), Mastercraft Nomad Seats, welded in add on family cage
SGT USMC ret. - Fallujah 06..........Never forgotten
'79 CJ7 with 4.2L w HEI /Dana 300 - twin sticked /Dana 30/AMC 20/ 33"BFGs-CCFabs tube fenders - Spyder Trail Stinger
http://www.jeepforum.com/forum/f22/project-franken-jeep-cj7-1981474/
mwroseberry is offline
post #4 of 68 Old 01-05-2015, 08:24 PM
csmetreyeon
1981 CJ7
81 CJ 7
258 bored 20 over Mopar MPFI
T176 tranny
Twin stick Dana 300
Eaton e locker in the Dana 30 Tom Woods shaft 3.54 Yukon gears
Auburn Ected in the AMC 20 Tom Woods shaft 3.54 Yukon gears
4" Skyjacker softride lift
BFG 33 12.50 Tires
Warrior SRS
Rear Currie shackles
Corbeau Racing suspension seats front with rear bench
Smitybuilt Locking 8" console
Autometer gauges
Rock Hard 4x4 Cage
Warn rock crawler bumpers front and rear with tire carrier
Rigid Industries flush mount reverse lights with bypass switch
Warn zeon 8s winch
JL Audio 5.25 components front 6x9 rear 6" sub in box behind bench
Future upgrades include:
Satelite radio on the way
Light bar mounted on hood
Fabricating nerf bars
Finished
Before Pic
csmetreyeon is offline
post #5 of 68 Old 04-02-2015, 07:46 AM
durban85cj7
1985 cj7
dana 60s with arb air lockers and 5.13's
onboard air
premiere power welder
37" mtr's on allied beadlocks
reverse shackle soa 5.5" rubicon express
new matkins frame
new tub,fenders and hood..new paint
rhino lined undercarriage and inside
mastercraft front and rear seats
6 point roll cage
corbeau 4 point harness belts
warn winch
i6 with howell tbi conversion and performance distributor dui
new soft top
durban85cj7 is offline
post #6 of 68 Old 04-18-2015, 11:41 AM
holliewood61
1981 CJ7
81 cj7
304
Th400
Dana 20
Scout 44, 4.88's, aussie locker
Front 4" pro comp. Rear 4" superlift
37" Irok's
Armor all the way around, tube fenders, front and rear home brew bumpers, warn 8274, edelbrock intake, hooker headers, howard's cam, msd ignition, msd atomic efi, led rock lights, tie rod and drag link flip, Dave's customs unlimited outboard kit, rear spring hanger sliders, rear storage shelf/spare tire carrier, mountain off road steering box brace.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #7 of 68 Old 04-18-2015, 07:41 PM
83cjnash
1983 CJ7
Specs
Year of CJ
Engine: AMC 258
Transmission: T-176 4 speed
Transfer Case: Dana 300
Front Axle: Dana 30, 4:10s
Rear Axle: Model 20, 4:10s
Suspension: 4 inch SUA with a lead removed to improve flex
Tires: 33x10.5 BFG Km2's
Additional Mods: Motorcraft 2150 carb, Jeep was done with a frame off, Dark Charcoal Grey paint, Homemade front and rear bumpers, tie rod flip, Smittybilt racing seats, autometer gauges, led directionals and tail/backup lights
Future:
linked suspension with ORI struts
350/turbo 400 or 302/t176
83 CJ7, 258 ci, T176, 33x10.5 km2 stock axles with 2.73 ratio
83cjnash is offline
post #8 of 68 Old 04-21-2015, 01:46 PM
aglinks
1983 CJ7
1983 Jeep CJ7 Laredo
TBI Chevy 350
TF999
Dana 300
Dana 30
AMC 20
2.5” Lift, I am unsure of the brand. It was installed when we got the jeep.
BFGooddrich T/A KO 33x10.50R15
Warn 9000lb winch, Nates 4x4 rear bumper and tire carrier, Superior one piece axels, air conditioning, bedlined interior, flex-a-lite dual core electric puller fan…nothing else exciting.
aglinks is offline
post #9 of 68 Old 04-29-2015, 03:06 PM
isteel4u
1985 CJ-7
258 inline 6
3" lift with 32 tires
Dana 300, AMC 20
Rhino Lined inside and out
T-176 Tran
8000 Lb. Ramsey Winch
Weber 38 DGS Carb
Corvette power brake upgrade
isteel4u is offline
post #10 of 68 Old 05-04-2015, 09:39 AM
kirkhurst
1977 CJ5
Specs
Year of CJ: 1977 CJ-5
Engine: 304 V-8
Transmission: T-150
Transfer Case: Dana 20
Front Axle: Dana 30 (3.54 ratio)
Rear Axle: AMC 20 (3.54 ratio)
Suspension: 2.5" Rancho
Tires: 32 X 11.5 BFGs
Additional Mods: Restoration completed Jan 2015, Original 1977 Jeep 7Y paint code "Tawny Orange", Duraspark II conversion and Team rush.
kirkhurst is offline
post #11 of 68 Old 06-12-2015, 04:36 PM
nomad316
1977 CJ7
nomad316 is offline
post #12 of 68 Old 06-12-2015, 07:36 PM
stewardxj
Mean Green Garage Queen (as my wife calls it)
'79 CJ-7, 258 CID AMC with Webber Carb and HEI ignition, T18 Trans with Granny low, Dana 30 Front axle with Powertrax locker, AMC 20 rear axle with forged axle shafts, 4" superlift suspension, 33-12.50x15 general Grabber A/Ts. 4WD Hardware fiberglass tub, Rescue Green paint, Painless wiring harness, 4.0l camshaft and serpentine belt drive, 8000lbs Warn winch and Warn premium locking hubs.
stewardxj is offline
post #13 of 68 Old 06-18-2015, 01:47 PM
71-CJ6
1971 CJ6
Specs
Year of CJ: 1971
Engine: Dauntless 225
Transmission: T-90
Transfer Case: Spicer 18
Front Axle: Dana 27
Rear Axle: Dana 44
Suspension: Stock with Pro Comp add-a-leafs
Tires: ProComp Extreme All Terrain
Additional Mods: Koenig Super Full Hardtop, Superwinch Tigershark 9.5,
240564_10100441603165854_278278260_o.jpg   277284_10100447301062224_510130739_o.jpg
CJ6... the Original Unlimited.
http://www.jeepforum.com/forum/f8/1971-cj6-rebuilding-i-go-3407890/
71-CJ6 is offline
post #14 of 68 Old 08-25-2015, 07:05 PM
Scmike1968
Junior Member
1979 CJ5
Specs
Year of CJ 1979
Engine 304
Transmission 3 speed
Transfer Case t20
Front Axle Dana 30
Rear Axle Dana 20
Suspension 2.5 rough country
Tires 32-11/50 x15 BFG
Additional Mods restoration completed August 2015. Silver Anniversary Edition . Complete frame off .
Scmike1968 is offline
post #15 of 68 Old 08-29-2015, 05:18 AM
Jeeper44mag
1978 CJ7
'78 CJ7
Nearly all stock AMC 304 V8
T-150 3 spd manual
Dana 20 Transfer case
D30 front (4.56)
AMC 20 rear (4.56)
~3" lift brand unknown
12.5" x33" x15" BFG AT's
Mediterranean Blue Pearl paint (Lexus)
RallyTops top
YJ hard doors w/diamond plate inside
Rhinolined inside and bottom
Stock Manifolds, 2-1 exhaust w/nicely tucked up Turbo muffler
Future mods - new rear bumper with tire carrier first
[IMG][/IMG]
[IMG][/IMG]
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
CJ of the Month Submissions for July!!! BESRK Jeep CJ Forum 1 06-22-2014 09:27 PM
CJ of the Month Submit Now.. Feb 2010 CJ of the Month BESRK Jeep CJ Forum 0 01-02-2010 07:21 PM
CJ of the Month Submissions.. for June.. Submit Now!! BESRK Jeep CJ Forum 0 05-03-2009 04:39 PM
May CJ of the Month Submissions!!! BESRK Jeep CJ Forum 0 04-01-2009 06:17 PM
March's CJ of the Month Submissions!! Now!! BESRK Jeep CJ Forum 0 03-03-2009 03:31 PM
