CJ of the Month for August 2014.. VOTE NOW!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ of the Month for August 2014.. VOTE NOW!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDan's Old as Dirt Birthday Sale!GEARSHADE Pocket Tops in stock and available at ROCKRIDGE
View Poll Results: CJ of the Month for August 2014.. VOTE NOW!!
83cjnash 5 5.81%
VooDoo2 23 26.74%
Offroaddaddy 27 31.40%
richclan 26 30.23%
azstsundevils 5 5.81%
Voters: 86. You may not vote on this poll
Unread 07-22-2014, 12:07 PM   #1
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Time to Pick a Winnah!!
Originally Posted by 83cjnash View Post
Specs
Year of CJ: 83 CJ7
Engine: AMC 258cid Motorcraft 2150 "Nuttered"
Transmission: Rebuilt T176
Transfer Case: Dana 300
Front Axle: Dana 30
Rear Axle: Model 20
Suspension: 4 inch lift kit with one leaf taken out in all four corners
Tires: 33x10.5 Bfg Km2
Additional Mods: I currently have 2.73's in my axles but have 4.10's in the mail and should be here this week. The roll bar is welded to the frame. I built the bumpers myself along with the D-ring mounts. Color is Dark Charcoal Grey. All lights are LED's except headlights. This entire Jeep was a frame off. It's my first vehicle and bought it at when I was 15. This one Jeep was made from a total of 4 Jeeps.
Originally Posted by VooDoo2 View Post
Specs
Year of CJ: 1983 CJ7 Laredo RHD
Engine: 258 I6
Transmission: TF999
Transfer Case: D300
Front Axle: D30
Rear Axle: AMC 20
Suspension: OME 2.5" OME Remote res Shocks
Tires: 32"Bighorns
Additional Mods: Converted AC to Onboard Air. Added 240ah battery system, 2000w invertor. Fully restored to stock.
Previously owned by Jeep AU for promotions, Did Rubicon trail in US then flown to AU and used as a show car. Sold to 4wd1.com to use as promotions car.
Originally Posted by Offroaddaddy View Post
Thanks all for the opportunity to share.
Year of CJ: 1986 Jeep CJ7
Engine: AMC 401, dyno'd 410hp, 470tq
Transmission: Ford T18a
Transfer Case: Atlas II 5.0
Front Axle: Currie Rockjock Dana 60, 35" spline chromoly RCV shafts, Yukon air locker, Yukon chromoly hubs/lockouts. "Solid 60" outer knuckles. Hi-steering, hydraulic assist steering. Willwood discs/calipers.
Rear Axle: Currie Rockjock Dana 60, 35" chromoly shafts, Yukon air locker. Disc brake conversion.
Suspension: Rubicon Express reverse eye SOA 1.5" springs
Tires: 42" Pitbull Rockers biasply. 16" Stazwork doublebead locks, with power valves.
Additional Mods: Flexalite aluminum rad and 3000cfm thermo controlled electric fan. LED headlights, KC HID Floodlights. PSC steering box and hydraulic assisted steering. Metalcloak front bumper/stinger, rock rails, front/rear fenders. Genright aluminum gas tank + steel skid. Genright aluminum rear tire carrier. Warn 8274-50 winch w/wireless control. Stainless steel brake lines front to back. Hydro-boost brakes. Holley Truck Avenger 770 cfm carb, with edelbrock airgap intake manifold. OBA.
Rancho 9000 remote reservoir adjustable shocks. Hedman Elite ceramic coated headers.
Click for sound, its a windows media file:
Originally Posted by richclan View Post
Year of CJ-8 Laredo 1982
Engine 258 stock except MC 2100 & Team Rush Mod
Transmission AX-15 next month [T-4 currently]
Transfer Case Dana 300
Front Axle Dana 30 456 gear, ARB air locker, SOLID cover, Warn Hubs
Rear Axle AMC 20 456 gear, ARB air locker, Superior 1 piece axles
Suspension Black Diamond 3" ,Boomerangs with 1" lift, Daystar 1" body
Tires 35 BFG KM-2
Armour Ricochet Rockers and Crusher Corners Painted to body color
Additional Mods I did all the restoration work myself. I wanted to make it stronger / better with off road in mind while keeping the classic scrambler look. ARB air compressor, Warn 9000 winch, Rock Hard Sport Cage, Contour electric fans, KC Lights, 4 Aux ground illuminating lights, YJ brake booster.
Originally Posted by azstsundevils View Post
Specs
Year of CJ: 1984 CJ7
Engine: 258 I6 with Weber 38
Transmission T5
Transfer Case D300
Front Axle D30 3.31
Rear Axle AMC 20 with One Piece Axles 3.31
Suspension Rubicon Express 4.5"
Tires 33x12.50 M/T Baja Claw TTCs on 15x10 ProComp 7069s
Additional Mods Warn Rock Crawler front and rear bumpers and winch
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 07-23-2014, 09:33 AM   #2
WSS
Ps:91
WSS's Avatar
1972 CJ5
WOW! what a line-up
www.metaltechus.com
Our Yellow 72 CJ5 build thread
Yellow Jeep club member #73802
WSS is online now   Reply With Quote
Unread 07-24-2014, 08:55 PM   #3
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
Voted, great group of jeeps here gents!
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
Congrats VegasGT the July Cherokee Of The Month!!
chris87xj is offline   Reply With Quote
Unread 07-25-2014, 05:52 PM   #4
BuckeyeNative
BuckeyeNative's Avatar
1974 CJ5
Great line-up overall.
Colorado Jeep Club Member #285
BuckeyeNative is offline   Reply With Quote
Unread 07-25-2014, 05:56 PM   #5
skizriz
skizriz's Avatar
1978 CJ7
Always a challenge to pick only one.
78 CJ7 258 TH400/Dana18 SOA/stock YJ springs 35" General Grabbers.
skizriz is offline   Reply With Quote
Unread 07-25-2014, 08:01 PM   #6
78FordF150
1983 CJ7
This is the best lineup I have seen in a long time!!!!!
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install [url]http://www.jeepforum.com/forum/f8/time-tranny-swap-upgrading-np435-1487201/[/url]
78FordF150 is offline   Reply With Quote
Unread 07-26-2014, 04:56 AM   #7
CommandoThunder
Go the Aussies LOL
CommandoThunder is offline   Reply With Quote
Unread 07-26-2014, 01:09 PM   #8
Gnomeo
Got my vote on!!!
Gnomeo is offline   Reply With Quote
Unread 07-28-2014, 06:38 PM   #9
keith460
Jeep. There's Only One
keith460's Avatar
Nice set of Jeep CJ's if I do say so myself.
Tough to make a choice but I have.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote
