CJ Model swap - JeepForum.com
post #1 of 7 Old 06-29-2002, 12:55 PM Thread Starter
klr650cj7zg1000
Question CJ Model swap
I have a glass cj7 in need of a full drive train. I'mnot looking to go extreme and would like to get out as easy as possible. Can I take another drivetrain and bolt it in? Is the only diff. in between a cj5 and cj7 drive the legnth(drive shaft)? There is a lot of info on engine swaps but not in conjunction with a tranny. Looking for ideas, Thanks.
klr650cj7zg1000 is offline
post #2 of 7 Old 06-29-2002, 03:19 PM
Steelhead
Post
Since your looking for some thing that would be easy and dependable I would try to find either a rusted out older jeep that runs good or a wrecked newer Jeep.That way you'll get a complete drive train and won't have to deal with adapters. And yes the only differance between a CJ-5 and a CJ-7 is the lenght.
Steelhead is offline
post #3 of 7 Old 06-29-2002, 05:23 PM
Happypappy
Post
By far the easiest way to go is with CJ drivetrains. This way you will have access to all the parts that are made to fit the application. It will be the most cost effective by far also. You can easily substitute V8 power in place of straight 6 power...direct bolt in! Flywheel and one mount are the only differences. AMC engines produced plenty of power and are know to last with the best of them.
Look for Jeep clubs in your state with Websites and 4-sale links. Look in e-bay and on the various forums here for 4-sale links. Rosser has one for example. Another example. Go to <a href="http://www.wilsons4x4.com" target="_blank">www.wilsons4x4.com</a> and browse the club links for their 4-sale areas.
Good luck and if you need help or a question answered e-mail me.
C. Lynn
Applications Engineer
Computerized Marine Diesel, IPS Systems
'06 Rubicon Unlimited
Happypappy is offline
post #4 of 7 Old 06-30-2002, 09:30 AM
Bulletproofcj7
Post
What year is your CJ7?
If you have a later model it will have widetrac axles, from around 1980-81 to 1986 I think.Before that they had narrow trac axles as did the CJ5's.
They will still fit but the wide trac seem to be more desireable as they offer more clearance for larger tires and articulation.
If you already have narrow trac axles now would be a good time to upgrade to the wide trac. they will bolt right in without a problem.
Just be sure that the front and rear gear ratios are the same or you will tear apart you drive train when in 4x4.
Also, the earlier hubs had 6 bolts to hold the locking hub as oposed to the newer models (again 1980-81 to 1986)that have 5.
I used the newer widetrac axles and the older knuckles and hubs with 6 bolts for more strength.
<a href="http://www.off-road.com/jeep/swb/articles/specgrid.htm" target="_blank">http://www.off-road.com/jeep/swb/articles/specgrid.htm</a>
hers some info that may help.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #5 of 7 Old 07-02-2002, 09:34 AM
mxg342
mxg342's Avatar
Post
Where are you located in PA?
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #6 of 7 Old 07-02-2002, 12:55 PM Thread Starter
klr650cj7zg1000
Post
In NEPA,
This yours or posted somewhere?
Would consider a trip out (about 5 hrs.).
Thanx
post #7 of 7 Old 07-02-2002, 02:13 PM
mxg342
mxg342's Avatar
Post
Right as of this minute I do not know of any. If you are willing to travel this far to get a decent frame and running gears I will search around and see what I can find though. I am acutally located in Kittanning PA which is about 2 hrs from State College. Let me know if you are interested and I will see what I can find.
mxg342 is offline
Later Model Head Swap on 258 - Can I drill out the holes? trailhead2004 Jeep CJ Forum 5 12-21-2009 08:31 AM
4.0 swap--late model engine mount bolt RockScar Jeep CJ Forum 3 12-14-2009 08:50 PM
Cj5 Early model to later model swap 6leafclover Jeep CJ Forum 5 01-31-2009 08:13 AM
AMC Model 20 one piece kit limited slip swap jeepster90 Jeep CJ Forum 1 01-20-2008 09:28 AM
model 30 swap 76 7 Jeep CJ Forum 1 03-22-2006 09:38 PM
