Quantcast CJ Lunchbox locker install - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > CJ Lunchbox locker install
Old 11-10-2009, 12:51 PM   #1
jeepers84
Anyone have experience with Powertrax No-slip and/or Lockright installations in AMC 20 rear diff.? Tech notes say they are not for use with one piece axles. Makes no sense to me. Opinions?
jeepers84 is offline   Reply With Quote
Old 11-10-2009, 01:34 PM   #2
Truck633
GO ONE MORE!!
Truck633's Avatar
I have run mine with no problems...I have a powertrax and alloy one piece axle shafts, ever now and then it kinda kicks you around a corner, but nothing major! I say do it!
Tom
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Originally Posted by schitzangiggles
It is no wonder we were the best and brightest, our toys weeded out the really stupid/unlucky one. That way there were less idiots to reproduce. Now since we have child proofed everything, we're being over run with Dee dee deees.
Truck633 is offline   Reply With Quote
Old 11-10-2009, 02:16 PM   #3
texasimport
1978 CJ5
Just took a detroit lunch box locker out of my AMC 20 with one piece axels. I just bought the jeep for my 17year old. Not the most fun to have a full time locker on snowy roads if your not 200% up for it.
78 304-CJ5
texasimport is offline   Reply With Quote
Old 11-10-2009, 02:58 PM   #4
CJhollic
1980 CJ7
Doesnt make sense. Mine works fine. Are you talking about the lunch box locker or thier No Slip application?
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline   Reply With Quote
Old 11-10-2009, 03:26 PM   #5
CJhollic
1980 CJ7
I just read the instructions to all 3 of thier products and dont see what you are referencing. The only reference to one piece axels I can find refers to the elimination of the thrust block because there is no need to adjust end play.
Weber 32/36 DGEV,
8000 lb Winch,
ViAir Onboard Air
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Mile Marker Hubs
Old 11-10-2009, 05:22 PM   #6
jeepers84
I found the disclaimer on two different on-line dealers sites in direct reference to the no-slip, which is basically a more civilized (and more expensive) version of the Lockrite, both made by Richmond Gear. A call to Richmond tech support yielded confirmation that there is a "potential" clearance issue when installed with one piece axles on both the Lockrite and the No-slip, but they wouldn't tell me what the solution is. I suspect they are just covering their butt on non-stock installations but I don't want to junk a $400.00 locker based on assumption.
Old 11-10-2009, 05:28 PM   #7
CJhollic
1980 CJ7
Very interesting. I wonder if there is something they just found out? Their installation instructions specifically mention taking the thrust block out to accomadate 1 piece axels.. I wonder if the clearance issue is if you dont remove the thrust block?
Either way I will be reading with interest as I have the Lock Right with 1 piece axels.
Weber 32/36 DGEV,
8000 lb Winch,
ViAir Onboard Air
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Mile Marker Hubs
Glock Forum
